[cadence] PSPICE仿真结果奇怪 望大神指点,谢谢
3212|2
 楼主| biaogreat 发表于 2019-3-31 18:39 | 显示全部楼层 |阅读模式
*Analysis directives:
.AC DEC 10 1 100k
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source 绝对值电路
V_V1         N00241 0 5Vdc
R_R1         N00985 N01316  1M
R_R2         N01316 VOUT  1M
V_V2         N00985 0 DC 0Vdc AC 1Vac
R_R3         N01262 N01289  200
**** RESUMING ac.cir ****
.END
ERROR(ORPSIM-15141): Less than 2 connections at node VOUT.
ERROR(ORPSIM-15141): Less than 2 connections at node N01262.
ERROR(ORPSIM-15141): Less than 2 connections at node N01289.
ERROR(ORPSIM-15142): Node N01262 is floating
ERROR(ORPSIM-15142): Node N01289 is floating
接的好好的为什么那么多错误?奇怪呀!!
零三翟邢止胃 发表于 2019-4-1 08:26 | 显示全部楼层
帮你顶住吧!!!!!
 楼主| biaogreat 发表于 2019-4-4 08:58 | 显示全部楼层
谢谢,我增加了负载电阻好了。不知道原因
