[资料分享] 短距离雷达 (SRR) 参考设计TIDEP-0092
940|2
 楼主| dirtwillfly 发表于 2019-3-31 22:25 | 显示全部楼层 |阅读模式
描述
The TIDEP-0092 reference design provides a foundation for short-range radar (SRR) applications using the AWR1642 evaluation module (EVM). This design allows the estimation and tracking of the position (in the azimuthal plane) and velocity of objects in its field of view up to 80 m,  travelling as fast as 90kmph.  The AWR1642 is configured to be a multi-mode radar, meaning that, while it tracks objects at 80m, it can also generate a rich point cloud of objects at 20m, so that both cars at a distance, and smaller obstacles close-by can be detected. Learn more with the TI Resource Explorer for Short Range Radar.
特性
  • Single-chip FMCW radio detection and ranging (RADAR) for SRR applications
  • Detect objects (such as cars and trucks) up to 80 m away with range resolution of 35 cm; objects 20-m away detectable with resolution of 4.3 cm
  • Clustering and tracking on detected outputs
  • Antenna field of view ±60° with angular resolution of approximately 15°
  • Source code for fast Fourier transform (FFT) processing and detection provided by mmWave software development kit (SDK)
  • AWR1642 EVM demonstrates the design
  • Radar front-end and detection configuration fully explained
 楼主| dirtwillfly 发表于 2019-3-31 22:31 | 显示全部楼层
Short Range Radar Reference Design Using AWR1642 Schematic and Block Diagram.pdf (180.75 KB, 下载次数: 1)
Short Range Radar Reference Design Using AWR1642 BOM.pdf (49.48 KB, 下载次数: 1)
Short Range Radar Reference Design Using AWR1642 Assembly Drawing.pdf (164.02 KB, 下载次数: 1)
Short Range Radar Reference Design Using AWR1642 PCB.pdf (942.1 KB, 下载次数: 1)
Short Range Radar Reference Design Using AWR1642 CAD Files.zip (920.18 KB, 下载次数: 1)
Short Range Radar Reference Design Using AWR1642 Gerber.zip (316.1 KB, 下载次数: 1)
AWR1642BOOST Schematic, Assembly, and BOM.zip (1.09 MB, 下载次数: 1)
AWR1642BOOST Design Database.zip (7.48 MB, 下载次数: 1)
 楼主| dirtwillfly 发表于 2019-3-31 22:33 | 显示全部楼层
使用AWR1642 的短距离雷达参考设计 (Rev. B).pdf (2.83 MB, 下载次数: 1)
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1203
