最新的MSP430普通IO模拟IIC程序!
2834|1
 楼主| lilihua0721 发表于 2011-9-26 20:12 | 显示全部楼层 |阅读模式
#include
#include
#include
#include
#define IicWpDirOut P6DIR |= BIT5
#define IicWpLow P6OUT &=~ BIT5
#define IicWpHig P6OUT |= BIT5
#define IicSclDirOut P6DIR |= BIT6
#define IicSclLow P6OUT &=~ BIT6
#define IicSclHig P6OUT |= BIT6
#define IicSdaDirOut P6OUT &= ~BIT7
#define IicSdaLow P6DIR |= BIT7
#define IicSdaHig P6DIR &=~ BIT7
#define IicSdaInSt P6IN & BIT7
bool AckErr;
//------------------------------ *** - 时间延时 - *** ------------------------------//
void Delay(unsigned int count)
unsigned int i;
_NOP();
_NOP();
for(i=count; i>0; i--);
void IIcDelay(void)
_NOP();
//-----***-IIC初始化-***-----//
void IicInit(void)
IicWpDirOut;
IicSdaDirOut;
IicSclDirOut;
IicWpHig;
IicSdaHig;
IicSclHig;
//-----***-IIC启示-***-----//
void IicStart(void)
IicSdaHig;//IicSda=1;
IIcDelay();
IicSclHig;//IicScl=1;
IIcDelay();
IicSdaLow;//IicSda=0;
IIcDelay();
IicSclLow;//IicScl=0;
IIcDelay();
//-----***-IIC停止-***-----//
void IicStop(void)
IIcDelay();
IIcDelay();
IIcDelay();
//-----***-IIC应答-***-----//
void SendAcknowledge(bool ack)
IicSdaDirOut;
if(ack)//IicSda=ack;
IicSdaHig;
else
IicSdaLow;
IIcDelay();
IIcDelay();
IIcDelay();
//-----***-从slave端读取一个数据-***-----//
unsigned char IicReceiveByte(void)
unsigned char i;
unsigned char bytedata=0;
IicSdaDirOut;
for(i=0;i<8;i++)
IIcDelay();
bytedata<<=1;
if(IicSdaInSt)
bytedata |=0x01;
else
bytedata &=0xfe;
IIcDelay();
IicSdaDirOut;
return bytedata;
//-----***-传送一个 Byte 数据到 slave-***-----//
void IicSentByte(unsigned char DataByte)
unsigned char i;
for(i=0;i<8;i++)
if(DataByte & 0x80)
else
DataByte <<=1;
IIcDelay();
IIcDelay();
IIcDelay();
IicSdaHig;//IicSda=1;-----Y------D---IicSdaDirIn
IIcDelay();
IIcDelay();
IIcDelay();
//-----***-无扇区读---多字节-***-----//
//读取指定器件无扇区指定地址多字节数据到指定地址
//Device=器件地址---单字节
//DataAdd=字节地址---单字节
void IicMuchByteRead(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
unsigned char i;
_DINT();
WDT();
IicInit();
IicStart();
IicSentByte(0xa0);
IicSentByte(DataAdd);
IicStart();
IicSentByte(0xa1);
for(i=DataLend-1;i>0;i--)
*DataDptr=IicReceiveByte();
DataDptr++;
SendAcknowledge(0);
SendAcknowledge(1);
IicStop();
WDT();
Delay(500);
_EINT();
//-----***-无扇区写---多字节-***-----//
//写入指定器件无扇区指定地址中的多字节数据
//Device=器件地址---单字节
//DataAdd=字节地址---双字节
//DataByte=被存放数据的地址
//DataLend=被存放数据的长度
void IicMuchByteWrite(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
unsigned char i;
_DINT();
WDT();
IicInit();
IicWpLow;
IicStart();
IicSentByte(0xa0);
for(i=DataLend;i>0;i--)
IicSentByte(*DataDptr);
DataDptr++;
IicStop();
WDT();
Delay(3500);
IicWpHig;
_EINT();
//---特别说明
//---利用430芯片来模拟IIC,是不能够把SDA设置为输出模式而是
//---设置为输入,然后利用方向控制器来输出高或者低
//---如下:
FVJFIFE 发表于 2011-9-27 11:22 | 显示全部楼层
网上的51代码改吧改吧就是
