1602液晶 单片机数字钟 按键
3140|11
 楼主| howard-ch 发表于 2011-10-7 16:50 | 显示全部楼层 |阅读模式
按键操作,功能键在时、分、秒间选择,在实验板上可以完成,但是选中好像是随机的,不稳定,请问:以下程序有错误吗?
1602数字钟
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit dula=P2^6;
sbit wela=P2^7;
sbit lcden=P3^4;
sbit lcdrs=P3^5;
sbit lcdrw=P3^6;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit rd=P3^7;
uchar i,j,shi,fen,miao,s1num;
uchar code table[]="2011-10-06 MON";
uchar code table1[]="00:00:00";
void delay(uint x)
        uint a,b;
        for(a=x;a>0;a--)
                for(b=110;b>0;b--);
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        lcdrs=1;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        dula=0;
        wela=0;
        lcdrw=0;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        for(i=0;i<14;i++)
                write_date(table[i]);
        write_com(0x80+0x40+3);
        for(i=0;i<8;i++)
                write_date(table1[i]);
        TMOD=0x01;
        TH0=(65535-50000)/256;
        TL0=(65535-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void write_sfm(uchar add,uchar date)
        uchar ge,shi;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+shi);
        write_date(0x30+ge);
void keyscan()
         rd=0;
         if(s1==0)
                 delay(5);
                if(s1==0)
                        s1num++;
                        while(!s1);
                        if(s1num==1)
                                 TR0=0;
                                write_com(0x80+0x40+10);
                                write_com(0x0f);
                        if(s1num==2)
                                write_com(0x80+0x40+7);
                        if(s1num==3)
                                write_com(0x80+0x40+4);
                        if(s1num==4)
                                s1num=0;
                                write_com(0x0c);
                                TR0=1;
void main()
        init();
        while(1)
                keyscan();
                if(j==20)
                        j=0;
                        miao++;
                        if(miao==60)
                                miao=0;
                                fen++;
                                if(fen==60)
                                        fen=0;
                                        shi++;
                                        if(shi==24)
                                                shi=0;
                                        write_sfm(3,shi);
                                write_sfm(6,fen);
                        write_sfm(9,miao);
void time0() interrupt 1
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        j++;
 楼主| howard-ch 发表于 2011-10-7 18:46 | 显示全部楼层
已经解决,谢谢大家了
 楼主| howard-ch 发表于 2011-10-7 18:48 | 显示全部楼层
怎么不能结贴?
ningling_21 发表于 2011-10-7 19:03 | 显示全部楼层
怎么解决的,怎么不分享一下...
 楼主| howard-ch 发表于 2011-10-7 19:43 | 显示全部楼层
少写了,S1num=0了
michaelqhj 发表于 2011-10-7 22:36 | 显示全部楼层
就是,以后解决了的一定要把解决方法晒出来
lidaji0 发表于 2011-10-19 09:08 | 显示全部楼层
不管了,先复制下来再说
ayb_ice 发表于 2011-11-9 11:18 | 显示全部楼层
看到"delay(5);"就没有兴趣了
 楼主| howard-ch 发表于 2011-11-10 22:12 | 显示全部楼层
:)为什么呢
sunocean 发表于 2011-11-10 23:05 | 显示全部楼层
看到"delay(5);"就没有兴趣了ayb_ice 发表于 2011-11-9 11:18
此话怎讲
 楼主| howard-ch 发表于 2011-11-11 20:32 | 显示全部楼层
是啊,此话何解?
 楼主| howard-ch 发表于 2011-11-13 21:04 | 显示全部楼层
是不是解放CPU不要浪费时间啊
