潜水7年第一贴。stm32的中断延迟是12周期么
3987|18
 楼主| lllaaa 发表于 2011-10-8 19:37 | 显示全部楼层 |阅读模式
我测试出来第一条指令到了20周期了。不知道香水版主能不能帮忙科普一下。
别的不说先上测试代码
  1. void ccc(uint32_t r0, uint32_t r1, uint32_t r2, uint32_t r3)
  3.     /* 此处由于ABI,寄存器已经被我赋值*/
  4.     while(r0);
  5. }
  6. int main(void)
  7. {
  8. /* System clocks configuration ---------------------------------------------*/
  9.     RCC_Configuration();
  10.     /* GPIO configuration ------------------------------------------------------*/
  11.    GPIO_Configuration();
  12.    TIM_Configuration();
  13.         GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource12);
  14. /* Configure EXTI0 line */
  15. EXTI_InitStructure.EXTI_Line = EXTI_Line12;
  16. EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;                EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  17. EXTI_Init(&EXTI_InitStructure);
  18. NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;        NVIC_Init(&NVIC_InitStructure);
  19.      /* 让r0 r1 r2 r3变成我想要的值,死循环 */
  20. ccc(0x40010808,1<<7,0x40010808,1<<7);
  21. }
然后中断处理程序里第一条指令就是给GPIO置位
  ALIGN
EXTI15_10_IRQHandler    PROC
                 EXPORT  EXTI15_10_IRQHandler
                 STR R3, [R2, #8]   ;给PA7置1.
但是我量到PA12的上升沿和PA7的上升沿相差了20个周期如图
 楼主| lllaaa 发表于 2011-10-8 19:46 | 显示全部楼层
哦。忘了说。stm32f103c8t6 cpu跑在24Mhz
香水城 发表于 2011-10-8 20:13 | 显示全部楼层
1)请查一下执行你的中断程序里的第一条指令需要几个周期,肯定不是0个周期。
2)从设置端口的指令结束,至端口处电平发生变化,因为总线的延迟,需要4个时钟周期的时间。
 楼主| lllaaa 发表于 2011-10-8 21:14 | 显示全部楼层
cortex-m3的文档上说str是1个周期的。
STR Rx,[Ry,#imm] is always one cycle. This is because the address generation is
performed in the initial cycle, and the data store is performed at the same time as
the next instruction is executing. If the store is to the store buffer, and the store
buffer is full, the next instruction is delayed until the store can complete. If the
store is not to the store buffer, such as to the Code segment, and that transaction
stalls, the impact on timing is only felt if another load or store operation is
executed before completion.
另外请问总线延迟这个时间在哪个资料上可以查到?多谢。
香水城 发表于 2011-10-9 11:05 | 显示全部楼层
不记得总线延迟时间在哪个资料上看到了,但这是一个事实。
 楼主| lllaaa 发表于 2011-10-9 13:44 | 显示全部楼层
但左算右算也拼不出多出来的那8个周期哇。
无冕之王 发表于 2011-10-9 22:39 | 显示全部楼层
楼主都潜水7年了:lol
 楼主| lllaaa 发表于 2011-10-10 13:30 | 显示全部楼层
呵呵。有另外一个id忘记叫啥了。所以只好用回这个
 楼主| lllaaa 发表于 2011-10-10 13:36 | 显示全部楼层
晚上回家试一试用sysclk计数器去测量一下到第一条isr指令的延迟
香水城 发表于 2011-10-10 13:40 | 显示全部楼层
对不起,我没有这么仔细地研究过,这个中断响应的12个周期是ARM核心的实现,由ARM的设计保证。
关于你那多出的8个周期,因为没有相应的资料,我只能做一个猜测:外部信号进入EXTI模块,产生了内部触发信号,这个内部触发信号进到Cortex-M核心有一定延迟,类似于输出信号的总线延迟。
为什么你要算这么精确?好奇吗?
 楼主| lllaaa 发表于 2011-10-10 13:43 | 显示全部楼层
业余爱好折腾折腾
想用gpio去实现usb时序。让低端的stm32也能有lowspeed usb功能。所以把c8t6降到24Mhz去做实验
香水城 发表于 2011-10-10 15:49 | 显示全部楼层
业余爱好折腾折腾
精神可嘉;但是对于有流水线的CPU,这样做法将非常地累,:$
 楼主| lllaaa 发表于 2011-10-10 17:03 | 显示全部楼层
是的。同样的指令前后组合不同,消耗的周期不一样。
cortex-m3的文档又写得不是那么清楚。很多地方需要自己测时间
昨天刚刚搞定usb前导sync的读取,为了精确读这1个字节就折腾了将近一周。
mcuisp 发表于 2011-10-10 18:42 | 显示全部楼层
24M运行时,FLASH可以关闭预读,时序可以精确些。
hsbjb 发表于 2011-10-10 18:59 | 显示全部楼层
爱折腾才能搞好技术,很看好楼主
cy757 发表于 2011-10-11 12:34 | 显示全部楼层
我试过在72M的情况下使用示波器检测从下降沿开始到STM32响应大概经历了1.2uS左右。
香水城 发表于 2011-10-11 12:41 | 显示全部楼层
你这个测试不如LZ的测试精确。
评分
参与人数 1威望 +1 收起 理由
lllaaa + 1
查看全部评分
 楼主| lllaaa 发表于 2011-10-11 14:25 | 显示全部楼层
咦。咋结贴哇
香水城 发表于 2011-10-11 17:01 | 显示全部楼层
咦。咋结贴哇
不给分的帖子,从一开始系统就会自动结帖。
