程序有什么问题
500|4
 楼主| yufe 发表于 2019-4-15 19:56 | 显示全部楼层 |阅读模式
void main (void)
   uchar reg_rddata;
   LCD_Reset();
   LCD_Initial();
   LCD_CLR();
   WriteDataToREG(0x00,0xcd);
   SetXY(0x00,0x00);
   Display_Chinese(tab1,160);
  reg_rddata = ReadDataFromREG(0xa0);
   reg_rddata |= 0x04;            //致能触摸中断
   WriteDataToREG(0xa0,reg_rddata);
   IT0=0;
   //EA=1;
   //EX0=1;
   while(1)
   if(reg_rddata & 0x40)
     reg_rddata &= 0xfb;            //禁能触摸中断
     get_touch();       //接收触摸键程序
      if(key_fg)
             key_fg=0x00;
             key_x2=key_x1;key_x1=touchx/100;
             key_y2=key_y1;key_y1=touchy/100;
             Delay_Nms(20);
            if((key_x2!= key_x1)||(key_y2!=key_y1)) continue;
             key= xytab[(key_y1-1)*7+key_x1-1];
              switch(key)    //判触摸地号11----77
              {    case 31:
                   case 32:
                   case 33:
                   case 34:
                   case 35:
                   case 36:
                   case 37:  {WriteDataToREG(0x10,0x2b);    //显示图形1
                                WriteDataToREG(0x00,0xc5);
                                lcd_photo(tab4);
                                Delay_Nms (3000);break;  }
                  case 41:
                   case 42:
                   case 43:
                   case 44:
                   case 45:
                   case 46:    //下面是显示文字
                   case 47:  {  WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                WriteDataToREG(0x00,0xc5); //0xcd写文字,0xc5写图形
                                 lcd_photo(tab5);
                                Delay_Nms (3000);break; }   //
                   case 51:   //下面可以增加
                   case 52:
                   case 53:
                   case 54:
                   case 55:
                   case 56:
                   case 57:  {WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                 lcd_photo(tab6);
                   case 61:
                   case 62:
                   case 63:
                   case 64:
                   case 65:
                   case 66:
                   case 67:  {WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                 lcd_photo(tab7);
                   case 71:
                   case 72:
                   case 73:
                   case 74:
                   case 75:
                   case 76:
                   case 77:  {WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                 lcd_photo(tab8);
                                Delay_Nms (3000);break; }   // 减键
zhuww 发表于 2019-4-15 20:00 | 显示全部楼层
你就不能将switch(key)
改成
switch(key / 10)
        case 3 :{WriteDataToREG(0x10,0x2b);    //显示图形1
                                lcd_photo(tab4);
        case 4 :{  WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                 lcd_photo(tab5);
        case 5 :{WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                 lcd_photo(tab6);
       case 6 :{WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                 lcd_photo(tab7);
       case 7 :{WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                 lcd_photo(tab8);
       default :
               break;
吗?
zhanglli 发表于 2019-4-15 20:03 | 显示全部楼层
这大程序看得我头疼
llia 发表于 2019-4-15 20:06 | 显示全部楼层
2楼正解
 楼主| yufe 发表于 2019-4-15 20:11 | 显示全部楼层
懂了,谢谢
