[Cortex-M0技术交流] IO中断问题
4088|4
 楼主| iam80 发表于 2011-10-11 19:38 | 显示全部楼层 |阅读模式
IO, gp, pi, GPIO, ST
我用聂子测试IO的中断时(上升沿中断)不起作用,但是只要我将示波器的探头接上相应IO口后,再用聂子测试此时中断正常。请问这是什么原因造成的啊?
以下是原代码(PA14,15中断)
#include <stdio.h>
#include "NUC122.h"
#include "DrvGPIO.h"
#include "DrvSYS.h"
void SelectClk_12M(void) //External 22MHZ
SYSCLK->PWRCON.XTL12M_EN=1;
/* Waiting for 12M Xtal stable */
DrvSYS_Delay(5000); //us级延时函数
DrvSYS_SelectHCLKSource (0);    //选择时钟源
void GPABCallback(uint32_t GPAStatus, uint32_t GPBStatus)
   if(GPAStatus & 0x4000)
      DrvGPIO_ClrBit(E_GPB,4);
      DrvSYS_Delayms(200);
   else if(GPAStatus & 0x8000)
   outpw((uint32_t)&GPIOA->DOUT, inpw((uint32_t)&GPIOA->PIN) ^ (1 << 7));
void GPCDCallback(uint32_t GPCStatus, uint32_t GPDStatus)
void Init_GPAInterrupt(void)
DrvGPIO_Open(E_GPA, 14, E_IO_INPUT);
DrvGPIO_EnableInt(E_GPA, 14, E_IO_RISING, E_MODE_EDGE);
DrvGPIO_SetIntCallback(GPABCallback, GPCDCallback);
// DrvGPIO_SetDebounceTime(5, E_DBCLKSRC_HCLK);    //端口消抖设置
// DrvGPIO_EnableDebounce(E_GPA, 14);
    //DrvGPIO_DisableInt(E_GPA, 14);
DrvGPIO_Open(E_GPA, 15, E_IO_INPUT);
DrvGPIO_EnableInt(E_GPA, 15, E_IO_RISING, E_MODE_EDGE);
// DrvGPIO_EnableDebounce(E_GPA, 15);
    //DrvGPIO_DisableInt(E_GPA, 15);
int main(void)
    UNLOCKREG();
    SelectClk_12M();
    LOCKREG();
Init_GPAInterrupt();
while(1)
{DrvGPIO_SetBit(E_GPB, 4);}
 楼主| iam80 发表于 2011-10-12 13:37 | 显示全部楼层
lixiaoxu2meng 发表于 2011-10-12 14:36 | 显示全部楼层
软件问题还是硬件问题?
 楼主| iam80 发表于 2011-11-1 14:18 | 显示全部楼层
忘了加上拉
hotpower 发表于 2011-11-1 14:23 | 显示全部楼层
