编译cc2530 zigbee程序以下报错是什么原因呢?
1355|0
 楼主| 快乐最重要 发表于 2019-4-19 10:42 | 显示全部楼层 |阅读模式
Error[Pe065]: expected a ";" C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 158
Warning[Pe012]: parsing restarts here after previous syntax error C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 206
Warning[Pe111]: statement is unreachable C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 209
Error[Pe020]: identifier "writeNV" is undefined C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 209
Error[Pe020]: identifier "idx" is undefined C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 216
Error[Pe020]: identifier "idx" is undefined C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 228
Error[Pe169]: expected a declaration C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 233
Warning[Pe012]: parsing restarts here after previous syntax error C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 242
Error[Pe169]: expected a declaration C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 243
Warning[Pe012]: parsing restarts here after previous syntax error C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 373
Error[Pe114]: function "zmain_ext_addr" was referenced but not defined C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 66
Error[Pe114]: function "zmain_dev_info" was referenced but not defined C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 70
Error[Pe114]: function "zmain_vdd_check" was referenced but not defined C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 71
Error[Pe114]: function "zmain_lcd_init" was referenced but not defined C:\Texas Instruments\ZStack-CC2530-2.5.1a\Projects\zstack\ZMain\TI2530DB\ZMain.c 74
Error while running C/C++ Compiler
