一个资源超级多的单片机,大家看看好用不?
1635|3
yejingang|  楼主 | 2011-10-19 14:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
● Instruction set compatible with standard 8051
● High performance processor architecture that executes instructions in one to eight clocks, speed up to 33 MHz
Memory
● 64/4K bytes of program flash with In-System Programming (ISP) capability
● 0/60K bytes of program flash with In-Application Programming (IAP) and ISP capability
● 1280 bytes of data RAM
- 256 bytes internal RAM
- 1K bytes auxiliary RAM (AUXRAM)
● FLASH memory with security protection
● Hardware In-System Programming (ISP) without boot code
Digital Peripherals
● Five 8-bit I/O ports
- Configurable I/O with quasi-bidirectional, input, push-pull, and open-drain modes
- 5 V tolerant I/O
● Three 16-bit timers/counters (Timer0/1/2)
● Full-duplex serial port (UART)
● Single Master and Slave I2C interface for external device communication
● 4-channel Programmable Counter Array (PCA) with PWM, Capture and Compare polarity setting for each channel
ayb_ice| | 2011-10-19 16:35 | 只看该作者
没有看到超多
只能说比标准51要多些
lyjian| | 2011-10-19 21:20 | 只看该作者
这点资源还叫“资源超级多”?
少见多怪了吧!
shizaigaole| | 2011-10-19 22:55 | 只看该作者
这还叫资源超多?
不叫资源超少就不错了
