[DemoCode下载]
M051内部测温度
560|2
598330983|  楼主 | 2019-4-30 20:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[M051][ADC]Measure_Internal_Temperature_Sensor.zip (496.55 KB)
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
* $Revision: 5 $
* $Date: 14/01/28 11:44a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series ADC Interface Controller Driver Sample Code
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLL_CLOCK       50000000
#define VBG                                                        1.20
#define Offset                                        724
#define Gain                                                -1.75
/* Define Function Prototypes        */
void SYS_Init(void);
void UART0_Init(void);
void AdcContScanModeTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* ADC clock source is 22.1184MHz, set divider to 100, ADC clock is 22.1184/100 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(100));
    /* Init I/O Multi-function        */
/* Init UART        */
void UART0_Init()
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* Function: AdcContScanModeTest        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   None.        */
/* Description:        */
/*   ADC continuous scan mode test.        */
void AdcContScanModeTest()
    int32_t  i32ConversionData;
                double Vref;
                double TempData;
    printf("+----------------------------------------------------------------------+\n");
    printf("|                 ADC for temperature sensor sample code                 |\n");
    printf("\nIn this test, software will get value from temperature sensor.\n");
                /* Enable Tempreture Sensor function */
                SYS->TEMPCR = SYS_TEMPCR_VTEMP_EN_Msk;
                /* Set the ADC operation mode as continuous scan, input mode as single-end and
                                 enable the analog input channel 7 */
                ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, 0x80);
                /* Configure the analog input source of channel 7 */
                ADC_CONFIG_CH7(ADC, ADC_ADCHER_PRESEL_INT_BANDGAP);
                /* Power on ADC module */
                ADC_POWER_ON(ADC);
                /* clear the A/D interrupt flag for safe */
                ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
                /* start A/D conversion */
                ADC_START_CONV(ADC);
    while(1)
                                        /* Wait conversion done */
                                        while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
                                        /* Stop A/D conversion */
                                        ADC_STOP_CONV(ADC);
                                        /* Calculate Vref by using conversion result of VBG */
                                        /* ConversionData = VBG * 4096 / Vref */
                                        i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 7);
                                        Vref = VBG * 4096 / (double)i32ConversionData;
                                        /* Delay */
                                        CLK_SysTickDelay(500000);
                                        ADC_CONFIG_CH7(ADC, ADC_ADCHER_PRESEL_INT_TEMPERATURE_SENSOR);
                                        ADC_STOP_CONV(ADC);
                                        /* Calculate value from temperature sensor */
                                        /* ConversionData = Vtemp(V) * 4096 / Vref    */
                                        /* Vtemp(mV) = Gain * Temperature + Offset */
                                        TempData = (((double)i32ConversionData * Vref / 4096) * 1000 - Offset) / Gain;
                                        printf("Conversion result of channel %d: 0x%X (%.2f oC)\n", 7, i32ConversionData, TempData);
                                        /* Delay */
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz\n", SystemCoreClock);
    /* Continuous scan mode test */
    AdcContScanModeTest();
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("\nExit ADC sample code\n");
    while(1);
heisexingqisi| | 2019-4-30 20:50 | 只看该作者
ADC 高级用法。
