| AD7991采用I2C总线,12位AD,我写的程序具体内容如下: uchar dat[6]={0,0,0,0,0,0};
 void delay()
 {_nop_();_nop_();}
 void start()
 sda=1;
 delay();
 scl=1;
 delay();
 sda=0;
 delay();
 void stop()
 sda=0;
 delay();
 scl=1;
 delay();
 sda=1;
 delay();
 void respons()
 uchar i=0;
 scl=1;
 delay();
 while((sda==1)&&(i<255))i++;
 scl=0;
 delay();
 void writebyte(uchar dat)
 uchar i,temp;
 temp=dat;
 for(i=0;i<8;i++)
 temp=temp>>1;
 scl=0;
 delay();
 sda=CY;
 delay();
 scl=1;
 delay();
 scl=0;
 delay();
 sda=1;
 delay();
 uchar readbyte()
 uchar i,k=0;
 scl=0;
 delay();
 sda=1;
 delay();
 for(i=0;i<8;i++)
 scl=1;
 delay();
 k=(k<<1)|sda;
 scl=0;
 delay();
 return k;
 void write_AD7991(uchar reg)
 start();
 writebyte(0x52);  //AD7991-0 Address:010 1000;AD7991-1 Address:010 1001
 respons();
 writebyte(reg);
 respons();
 stop();
 void read_AD7991()
 uchar i;
 start();
 write_AD7991(0x53);
 respons();
 for(i=0;i<3;i++)    //read 6 bytes,3 ADC value
 dat[2*i]=readbyte();
 sda=0;
 delay();
 scl=1;
 delay();
 dat[2*i+1]=readbyte();
 sda=1;
 delay();
 scl=1;
 delay();
 scl=0;
 stop();
 存在问题:把AD转换后的值通过串口送到上位机,AD值都是FF。现已确定串口部分程序无问题,问题应该出在上面的程序,请各位前辈指点!
×本帖子中包含更多资源您需要 登录 才可以下载或查看,没有账号?注册
