[圈圈教你玩USB] HID ReadFile 读错误1784
5669|0
 楼主| zgbxzws 发表于 2011-10-28 14:35 | 显示全部楼层 |阅读模式
//发送LED的状态。
BOOL CMyUsbHidTestAppDlg::SendLedStatus()
BOOL Result;
UINT LastError;
UINT i;
CString Str;
//如果设备没有找到,则返回失败
if(MyDevFound==FALSE)
        AddToInfOut("设备未找到");
  return FALSE;
//如果句柄无效,则说明打开设备失败
if(hWriteHandle==INVALID_HANDLE_VALUE)
  AddToInfOut("无效的写报告句柄,可能是打开设备时失败");
  return FALSE;
//如果数据仍在发送中,则返回失败
if(DataInSending==TRUE)
  AddToInfOut("数据正在发送中,暂时不能发送");
  return FALSE;
//设置要发送报告的数据
//WriteReportBuffer[0]=0x00;   //报告ID为0
//WriteReportBuffer[1]=LedStatus; //将LED状态放到缓冲区中
WriteReportBuffer[1]=0x00;
WriteReportBuffer[1]=0x25;
        WriteReportBuffer[2]=0x2B;
        WriteReportBuffer[3]=0x02;
        WriteReportBuffer[4]=0x01;
        WriteReportBuffer[5]=0x01;
        WriteReportBuffer[6]=0x2F;
        WriteReportBuffer[7]=0x21;
//显示发送数据的信息
AddToInfOut("发送输出报告9字节");
Str="";
for(i=0;i<64;i++)
  Str+=itos(WriteReportBuffer[i],16).Right(2)+" ";
        AddToInfOut(Str,FALSE);
//设置正在发送标志
        DataInSending=TRUE;
//调用WriteFile函数发送数据
Result=WriteFile(hWriteHandle,WriteReportBuffer,65,NULL,&WriteOverlapped);
if(Result==1)
          Result=ReadFile(hReadHandle,ReadReportBuffer,64,NULL,&ReadOverlapped);
          LastError=GetLastError();    //总返回1784   是什么情况
          DataInSending=FALSE;
   return TRUE;
Bus Hound工具获取到的数据是正常的,为什么读总返回错误代码1784呢
Device  Phase  Data         Description       Cmd.Phase.Ofs(rep)
  29.2  OUT    25 2b 02 01  %+..                     1.1.0(6)
               01 2f 21 00  ./!.                     1.1.4
               00 00 00 00  ....                     1.1.8
               00 00 00 00  ....                     1.1.12
               00 00 00 00  ....                     1.1.16
               00 00 00 00  ....                     1.1.20
               00 00 00 00  ....                     1.1.24
               00 00 00 00  ....                     1.1.28
  29.2  IN     25 2b 12 01  %+..                     2.1.0(6)
               01 00 27 10  ..'.                     2.1.4
               00 00 00 27  ...'                     2.1.8
               11 11 24 00  ..$.                     2.1.12
               43 eb 00 00  C...                     2.1.16
               da eb 21     ..!                      2.1.20
