task1.axf: Error: L6238E: startup.o(RESET) contains invalid call from '~PRES8 (The user did not require code to preserve 8-byte aligment of 8-byte data objects)' function to 'REQ8 (Code was permitted to depend on the 8-byte aligment of 8-byte data items)' function FIQ_Exception.
麻烦各位帮满看看 |
