BLE_OTA_FixedStack_Bootloadable01编译报错,求指导
813|0
 楼主| junkerliu 发表于 2019-5-6 15:10 | 显示全部楼层 |阅读模式
报错有2个:
1. Build error: cannot open linker script file BootloaderSymbolsGcc.ld: No such file or directory
2. Build error: The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
