[ZLG-ARM] 转:电子琴 带存储
2267|2
 楼主| FVJFIFE 发表于 2011-10-30 14:40 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
uchar a=0,b=0,c=0,d=0;
sbit d1=P3^0;
sbit d2=P3^1;
sbit d3=P3^4;
sbit d4=P3^5;
sbit d5=P3^6;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uint code table1[]={
   0,248,249,250,
250,251,251,252,
252,252,253,253,
253,253,254  };
uint code table2[]={
   0,136, 62, 19,
104,  5,144, 12,
  68,209,  9, 52,
130,200,  6   };
uchar table3[80];
uchar qm;
uchar mm,nn;
void display(uchar a,uchar b,uchar c,uchar d);
void delay(uint z);
void yinyue(uchar q);
uchar key(void);
void fangyin(void);
void lvyin(void);
void main(void)
uchar a1;
table3[0]=15;
display(a,b,c,d);
EA=1;
EX0=1;
EX1=1;
IP=0x08;
IT0=0;
IT1=0;
while(1)
      table3[79]=15;
           d2=1;
           d3=0;
     d4=0;
     d5=0;
     nn=17;
     display(a,b,c,d);
           P2=0xf0;
     mm=P2;
     mm=(mm&0xf0);
     if(mm!=0xf0)
         nn=key();
         if(nn<=16)
    d=c;
    c=b;
    b=a;
    a=nn;
     if(nn<=14)
   yinyue(nn);
   nn=0;
   if(nn==15)
   d3=1;
    mm=0xf0;
    while(mm==0xf0)
      while(mm==0xf0)
    ;P2=0xf0;
       mm=P2;
       mm=(mm&0xf0);
    display(a,b,c,d);
      display(a,b,c,d);
      ;P2=0xf0;
       mm=P2;
       mm=(mm&0xf0);
     a1=0;
     while(a1<=250)
      a1++;
      display(a,b,c,d);
      P2=0xf0;
            mm=P2;
            mm=(mm&0xf0);
            if(mm==0xf0)
        d3=1;
        a1=253;
     if(a1<=252)
      display(a,b,c,d);
      d3=0;
      d4=1;
      lvyin();
      d4=0;
      display(a,b,c,d);
      display(a,b,c,d);
      display(a,b,c,d);
      if(a1>=253)
      display(a,b,c,d);
      d3=0;
      d5=1;
      fangyin();
      d5=0;
      display(a,b,c,d);
      display(a,b,c,d);
      display(a,b,c,d);
     d3=0;
        uint jia;
  uchar ce;
       TMOD=0x10;
  ET1=1;
  qm=q;
  TH1=(65536-table1[q])/256;
  TL1=(65536-table1[q])%256;
  display(a,b,c,d);
        if(q!=0)
  {TR1=1;}
  if(q==0)
     {TR0=0;}
  for(jia=0;jia<=300;jia++)
     P2=0xf0;
     ce=P2;
     ce=(ce&0xf0);
     if(ce!=0xf0)
     jia=301;
     display(a,b,c,d);
   TR1=0;
void time1() interrupt 3
{ TH1=table1[qm];
TL1=table2[qm];
     d1=~d1;
    P0=0xff;
;P1=table[a];
;P0=0xfe;
delay(1);
;P0=0xff;
;P1=table;
;P0=0xfd;
delay(1);
;P0=0xff;
;P1=table[c];
;P0=0xfb;
delay(1);
P0=0xff;
P1=table[d];
P0=0xf7;
delay(1);
P0=0xff;
void delay(uint z)
{ uchar p,qq;
for(p=0;p<=z;p++)
    for(qq=0;qq<=57;qq++);
uchar key(void)
{ uchar hu,num;
     display(a,b,c,d);
    display(a,b,c,d);
    display(a,b,c,d);
  P2=0xf0;
  hu=P2;
  hu=(hu&0xf0);
  if(hu==0xf0)
     num=17;
  if(hu!=0xf0)
    P2=0xfe;
   hu=P2;
   hu=(hu&0xf0);
   switch(hu)
     case 0xe0:num=3;
    break;
    case 0xd0:num=2;
    break;
    case 0xb0:num=1;
    break;
    case 0x70:num=0;
    break;
   P2=0xfd;
   hu=P2;
   hu=(hu&0xf0);
   switch(hu)
     case 0xe0:num=7;
    break;
    case 0xd0:num=6;
    break;
    case 0xb0:num=5;
    break;
    case 0x70:num=4;
    break;
   P2=0xfb;
   hu=P2;
   hu=(hu&0xf0);
   switch(hu)
     case 0xe0:num=11;
    break;
    case 0xd0:num=10;
    break;
    case 0xb0:num=9;
    break;
    case 0x70:num=8;
    break;
   P2=0xf7;
   hu=P2;
   hu=(hu&0xf0);
   switch(hu)
     case 0xe0:num=15;
    break;
    case 0xd0:num=14;
    break;
    case 0xb0:num=13;
    break;
    case 0x70:num=12;
    break;
  P2=0xf0;
     hu=P2;
  while(hu!=0xf0)
   P2=0xf0;
   hu=P2;
   display(a,b,c,d);
     display(a,b,c,d);
   while(hu!=0xf0)
{ display(a,b,c,d);
  P2=0xf0;
  hu=P2;
  return num;
void int0() interrupt 0
  yinyue(0);
  yinyue(1);
  yinyue(2);
  yinyue(3);
  yinyue(4);
  yinyue(5);
  yinyue(6);
  yinyue(7);
  yinyue(8);
  yinyue(9);
  yinyue(10);
  yinyue(11);
  yinyue(12);
  yinyue(13);
  yinyue(14);
void int1() interrupt 2
  yinyue(0);
  yinyue(1);
  yinyue(1);
  yinyue(2);
  yinyue(4);
  yinyue(3);
  yinyue(1);
  yinyue(1);
  yinyue(2);
  yinyue(1);
  yinyue(5);
  yinyue(4);
  yinyue(1);
  yinyue(1);
  yinyue(6);
  yinyue(4);
  yinyue(3);
  yinyue(2);
  yinyue(7);
  yinyue(7);
  yinyue(6);
  yinyue(4);
  yinyue(5);
  yinyue(4);
  yinyue(0);
  yinyue(1);
  yinyue(1);
  yinyue(2);
  yinyue(4);
  yinyue(3);
  yinyue(1);
  yinyue(1);
  yinyue(2);
  yinyue(1);
  yinyue(5);
  yinyue(4);
  yinyue(1);
  yinyue(1);
  yinyue(6);
  yinyue(4);
  yinyue(3);
  yinyue(2);
  yinyue(7);
  yinyue(7);
  yinyue(6);
  yinyue(4);
  yinyue(5);
  yinyue(4);
void lvyin(void)
   { uchar c1=0,c2=0;
   P2=0xf0;
      mm=P2;
      mm=(mm&0xf0);
     display(a,b,c,d);
   while(mm!=0xf0)
      while(mm!=0xf0)
    P2=0xf0;
       mm=P2;
       mm=(mm&0xf0);
    display(a,b,c,d);
      display(a,b,c,d);
      P2=0xf0;
       mm=P2;
       mm=(mm&0xf0);
while(c2!=15)
    {  display(a,b,c,d);
    P2=0xf0;
       mm=P2;
       mm=(mm&0xf0);
   if(mm!=0xf0)
     nn=key();
     if(nn<=15)
       table3[c1]=nn;
       d=c;
       c=b;
       b=a;
       a=nn;
       c2=nn;
       yinyue(nn);
       display(a,b,c,d);
       c1++;
void fangyin(void)
   uchar c4=0,c5=0;
   while(c4!=15)
    c4=table3[c5];
    d=c;
    c=b;
    b=a;
    a=c4;
    display(a,b,c,d);
    yinyue(c4);
    c5++;
金鱼木鱼 发表于 2011-10-30 17:10 | 显示全部楼层
在啥编译器下面的啊
jingbaobao 发表于 2011-11-23 13:28 | 显示全部楼层
是啊,用的什么编译器啊。
