用sprintf老报错一般是啥原因
1069|5
 楼主| xxmmi 发表于 2019-5-9 23:09 | 显示全部楼层 |阅读模式
用sprintf老报错一般是啥原因
kangzj 发表于 2019-5-9 23:12 | 显示全部楼层
程序呢
 楼主| xxmmi 发表于 2019-5-9 23:14 | 显示全部楼层
#include <project.h>
int main()
    /* Place your initialization/startup code here (e.g. MyInst_Start()) */
    int16 res;
    float vol;
    int16 value;
    char tstr;
    ADC1_Start();
    LCD1_Start();
    LCD1_ClearDisplay();
    ADC1_StartConvert();
    LCD1_Position(0,0);
    LCD1_Position(1,8);
    for(;;)
     while(ADC1_IsEndConversion(ADC1_WAIT_FOR_RESULT)==0);
      res=ADC1_GetResult16();
      vol=ADC1_CountsTo_Volts(res);
      sprintf(tstr,"%+1.4f",vol);
      value=(int)80*vol/5.0;
      if(Pin_2_Read()==0)
        LCD1_Position(0,0);
        LCD1_PrintString("Measured Voltage is:");
        LCD1_Position(1,0);
        LCD1_PrintString(tstr);
        LCD1_PrintString(" V                ");
    else
        LCD1_DrawHorizontalBG(1,0,80,value);
   /* Place your application code here. */
/* [] END OF FILE */
zwll 发表于 2019-5-9 23:18 | 显示全部楼层
是不是缺少包含的头文件??
 楼主| xxmmi 发表于 2019-5-9 23:21 | 显示全部楼层
默认不为0吗
ayb_ice 发表于 2019-5-13 16:45 | 显示全部楼层
第一个参数是缓冲区地址
