[STM32L0] L052 普通的定时器如何打开
1181|5
 楼主| chh44 发表于 2019-5-13 18:09 | 显示全部楼层 |阅读模式
刚接触STM32L0系列的芯片,现在的SDK都是通过st的工具cube mx生成的,但定时器没有跑进设定的中断去。
请大神帮忙看看代码哪里出了问题,如果能提供份能正常跑起来的定时器代码也感激万分
void SysBaseTimerInit(void)
        /* USER CODE BEGIN TIM21_Init 0 */
        /* USER CODE END TIM21_Init 0 */
        TIM_SlaveConfigTypeDef sSlaveConfig = {0};
        TIM_MasterConfigTypeDef sMasterConfig = {0};
        TIM_OC_InitTypeDef sConfigOC = {0};
        /* USER CODE BEGIN TIM21_Init 1 */
        /* USER CODE END TIM21_Init 1 */
        htim21.Instance = TIM21;
        htim21.Init.Prescaler = 1600;
        htim21.Init.CounterMode = TIM_COUNTERMODE_UP;
        htim21.Init.Period = 10000;
        htim21.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
        htim21.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
        if (HAL_TIM_Base_Init(&htim21) != HAL_OK)
                _Error_Handler(__FILE__, __LINE__);
        if (HAL_TIM_OC_Init(&htim21) != HAL_OK)
        sSlaveConfig.SlaveMode = TIM_SLAVEMODE_RESET;
        sSlaveConfig.InputTrigger = TIM_TS_ITR0;
        if (HAL_TIM_SlaveConfigSynchronization(&htim21, &sSlaveConfig) != HAL_OK)
        sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
        sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
        if (HAL_TIMEx_MasterConfigSynchronization(&htim21, &sMasterConfig) != HAL_OK)
        sConfigOC.OCMode = TIM_OCMODE_TIMING;
        sConfigOC.Pulse = 0;
        sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
        sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
        if (HAL_TIM_OC_ConfigChannel(&htim21, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef * htim)
        //if(htim->Instance == TimHandle.Instance)
                if(a == 1)
                        LED1_WRITE(0);
                        a = 0;
                else
                        a = 1;
                        LED1_WRITE(1);
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base)
        if(htim_base->Instance==TIM21)
                /* USER CODE BEGIN TIM21_MspInit 0 */
                /* USER CODE END TIM21_MspInit 0 */
                /* Peripheral clock enable */
                __HAL_RCC_TIM21_CLK_ENABLE();
                /* TIM21 interrupt Init */
                HAL_NVIC_SetPriority(TIM21_IRQn, 0, 2);
                HAL_NVIC_EnableIRQ(TIM21_IRQn);
                /* USER CODE BEGIN TIM21_MspInit 1 */
                /* USER CODE END TIM21_MspInit 1 */
蝴蝶泉2018 发表于 2019-5-15 11:52 | 显示全部楼层
软件库里现成的外设代码啊,在上面改写或者参照就简单多了
heimaojingzhang 发表于 2019-6-12 09:34 | 显示全部楼层
难道不可以用cube生成吗
keaibukelian 发表于 2019-6-12 10:01 | 显示全部楼层
光看这部分代码 没有什么结论
labasi 发表于 2019-6-12 10:04 | 显示全部楼层
中断向量指过去了吗
 楼主| chh44 发表于 2019-6-15 17:22 | 显示全部楼层
可以了,用cube生成代码就OK了
个人签名:Hello world!
