[STM8] 做过STM8--bootloader的进来围观指导一下~~
6579|39
 楼主| hzocce 发表于 2019-7-16 16:42 | 显示全部楼层
kingkits 发表于 2019-7-16 15:52
你统一把中断向量表定义到RAM中就好了,具体怎么实现,应该有资料说明的
RAM 是不是也是一个地址?
我看上面的就是从0x8000开始,到0xffff结束。
aolin 发表于 2019-7-16 15:52
你的问题在于中断向量表没有做remap所致
如何remap?
aolin 发表于 2019-7-16 18:22 | 显示全部楼层
在bootloader里面remap
extern void _stext();     /* startup routine */
struct interrupt_vector const UserISR_IRQ[32] @ MAIN_USER_RESET_ADDR;
//redirected interrupt table
struct interrupt_vector const _vectab[] = {
    {0x82, (interrupt_handler_t)_stext}, /* reset */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+ 1)}, /* trap  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+ 2)}, /* irq0  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+ 3)}, /* irq1  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+ 4)}, /* irq2  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+ 5)}, /* irq3  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+ 6)}, /* irq4  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+ 7)}, /* irq5  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+ 8)}, /* irq6  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+ 9)}, /* irq7  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+10)}, /* irq8  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+11)}, /* irq9  */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+12)}, /* irq10 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+13)}, /* irq11 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+14)}, /* irq12 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+15)}, /* irq13 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+16)}, /* irq14 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+17)}, /* irq15 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+18)}, /* irq16 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+19)}, /* irq17 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+20)}, /* irq18 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+21)}, /* irq19 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+22)}, /* irq20 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+23)}, /* irq21 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+24)}, /* irq22 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+25)}, /* irq23 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+26)}, /* irq24 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+27)}, /* irq25 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+28)}, /* irq26 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+29)}, /* irq27 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+30)}, /* irq28 */
    {0x82, (interrupt_handler_t)(UserISR_IRQ+31)}, /* irq29 */
 楼主| hzocce 发表于 2019-7-17 13:40 | 显示全部楼层
在bootloader里面remap
struct interrupt_vector const  ...
感谢"aolin"的指导!
也就是将这个函数,放在main函数之外的就可以?
有写它就可以,不需要在其他地方做任何的调动?
我看这个地址地址偏移了?
原来应该就是0x8000了? 然后选择从MAIN_USER_RESET_ADDR地址开始?
是这个意思么?
liuxiang5119 发表于 2019-7-17 14:45 | 显示全部楼层
之前有做过stm32f207的boot   记得是在APP 函数启动后 要加一句向量跳转吧  //SCB->VTOR = FLASH_BASE | 0x10000; /* Vector Table Relocation in Internal FLASH. */   好久不做  忘了  boot里边应该也有个地址跳转的
 楼主| hzocce 发表于 2019-7-18 08:30 | 显示全部楼层
之前有做过stm32f207的boot   记得是在APP 函数启动后 要加一句向量跳转吧  //SCB->VTOR = FLASH_BASE | 0x ...
STM8 听说这样跳不了
aolin 发表于 2019-7-18 09:02 | 显示全部楼层
感谢"aolin"的指导!
bootloader里面的中断向量表用这个表代替,这个表内的跳转地址实际就是调转到你应用程序内的中断向量表的地址
 楼主| hzocce 发表于 2019-7-18 13:57 | 显示全部楼层
bootloader里面的中断向量表用这个表代替,这个表内的跳转地址实际就是调转到你应用程序内的中断向量表的 ...
我的意思这个向量表放在什么地方?
//---------------省略--------------------------
void main(void){
//----省略----
是这种形式么?
aolin 发表于 2019-7-18 14:15 | 显示全部楼层
我的意思这个向量表放在什么地方?
这个表就是中断向量表呀,你平时的程序的中断向量表的位置呀
不过这个需要放在你的bootloader程序的中断向量表的位置
 楼主| hzocce 发表于 2019-7-18 14:39 | 显示全部楼层
不过这个需要放在你的bootloader程序的中断 ...
高手,我从来没有写过中断向量,也没有去注意过这个。
真的不知道放在哪里去!
我只知道开启中断,然后在it.c的函数中去添加我需要中断处理的内容,没有涉及过表。
还麻烦指导~~
aolin 发表于 2019-7-18 20:05 | 显示全部楼层
真的不知道放在哪里去!
不是吧
那你是用什么工具开发的?
STVD配cosmic吗? stvd在建立工程时会自动生成一个名字为stm8_interrupt_vector.c的源文件,这个文件的内容就是中断向量表,你就在上面改就可以了
/*        BASIC INTERRUPT VECTOR TABLE FOR STM8 devices
*        Copyright (c) 2007 STMicroelectronics
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
        unsigned char interrupt_instruction;
        interrupt_handler_t interrupt_handler;
@far @interrupt void NonHandledInterrupt (void)
        /* in order to detect unexpected events during development,
           it is recommended to set a breakpoint on the following instruction
        return;
        {0x82, NonHandledInterrupt}, /* trap  */
        {0x82, NonHandledInterrupt}, /* irq0  */
        {0x82, NonHandledInterrupt}, /* irq1  */
        {0x82, NonHandledInterrupt}, /* irq2  */
        {0x82, NonHandledInterrupt}, /* irq3  */
        {0x82, NonHandledInterrupt}, /* irq4  */
        {0x82, NonHandledInterrupt}, /* irq5  */
        {0x82, NonHandledInterrupt}, /* irq6  */
        {0x82, NonHandledInterrupt}, /* irq7  */
        {0x82, NonHandledInterrupt}, /* irq8  */
        {0x82, NonHandledInterrupt}, /* irq9  */
        {0x82, NonHandledInterrupt}, /* irq10 */
        {0x82, NonHandledInterrupt}, /* irq11 */
        {0x82, NonHandledInterrupt}, /* irq12 */
        {0x82, NonHandledInterrupt}, /* irq13 */
        {0x82, NonHandledInterrupt}, /* irq14 */
        {0x82, NonHandledInterrupt}, /* irq15 */
        {0x82, NonHandledInterrupt}, /* irq16 */
        {0x82, NonHandledInterrupt}, /* irq17 */
        {0x82, NonHandledInterrupt}, /* irq18 */
        {0x82, NonHandledInterrupt}, /* irq19 */
        {0x82, NonHandledInterrupt}, /* irq20 */
        {0x82, NonHandledInterrupt}, /* irq21 */
        {0x82, NonHandledInterrupt}, /* irq22 */
        {0x82, NonHandledInterrupt}, /* irq23 */
        {0x82, NonHandledInterrupt}, /* irq24 */
        {0x82, NonHandledInterrupt}, /* irq25 */
        {0x82, NonHandledInterrupt}, /* irq26 */
        {0x82, NonHandledInterrupt}, /* irq27 */
        {0x82, NonHandledInterrupt}, /* irq28 */
        {0x82, NonHandledInterrupt}, /* irq29 */
 楼主| hzocce 发表于 2019-7-22 08:36 | 显示全部楼层
不是吧
那你是用什么工具开发的?
STVD配cosmic吗? stvd在建立工程时会自动生成一个名字为stm8_interrupt ...
难怪,原来是STVD~~
我用的是IAR ,所有不知道这个放在哪里去。
IAR 怎么弄呢?
aolin 发表于 2019-7-22 08:56 | 显示全部楼层
难怪,原来是STVD~~
趁此机会果断转STVD呀
 楼主| hzocce 发表于 2019-7-23 09:00 | 显示全部楼层
趁此机会果断转STVD呀
能指导下IAR么?
aolin 发表于 2019-7-23 12:02 | 显示全部楼层
能指导下IAR么?
我都没有用过iar for stm8,无能为力
 楼主| hzocce 发表于 2019-7-24 08:33 | 显示全部楼层
谢谢~~~
蝴蝶泉2018 发表于 2019-7-24 12:16 | 显示全部楼层
建议下载一下官方的应用比价AN2659和相应的软件例程。里面有IAR的工程。看一遍就一目了然了,知道程序架构以及编译器特殊设置的方式
磨砂 发表于 2019-8-6 10:24 | 显示全部楼层
.icf文件是干嘛用的呢
晓伍 发表于 2019-8-6 10:28 | 显示全部楼层
目前还没接触过stm8  因该很小巧啊
八层楼 发表于 2019-8-6 10:37 | 显示全部楼层
请教楼主  bootloader的引脚是如何连接的呢
