[STM8] 最新STM8S003和STM8S005系列产品
17703|32
 楼主| 香水城 发表于 2011-11-8 17:33 | 显示全部楼层 |阅读模式
共5款产品:
STM8S003F3: TSSOP20封装和UFQFPN20(3x3)封装
STM8S003K3: LQFP32(7x7)封装
STM8S005K6: LQFP32(7x7)封装
STM8S005C6: LQFP48(7x7)封装
数据手册:
STM8S003xx: http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/DM00024550.pdf
STM8S005xx: http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/DM00037613.pdf
 楼主| 香水城 发表于 2011-11-8 17:34 | 显示全部楼层
STM8S003 Key Features
Key Features
  • Core
    • 16 MHz advanced STM8 core with Harvard architecture and 3-stage pipeline
    • Extended instruction set
  • Memories
    • Program memory: 8 Kbytes Flash; data retention 20 years at 55 °C after 100 cycles
    • RAM: 1 Kbytes
    • Data memory: 128 bytes of true data EEPROM; endurance up to 100 000 write/erase cycles
  • Clock, reset and supply management
    • 2.95 to 5.5 V operating voltage
    • Flexible clock control, 4 master clock sources:
      • Low power crystal resonator oscillator
      • External clock input
      • Internal,user-trimmable 16 MHz RC
      • Internal low power 128 kHz RC
    • Clock security system with clock monitor
    • Power management:
      • Low power modes (wait, active-halt, halt)
      • Switch-off peripheral clocks individually
    • Permanently active,low consumption power-on and power-down reset
  • Interrupt management
    • Nexted interrupt controller with 32 interrupts
    • Up to 27 external interrupts on 6 vectors
  • Timers
    • Advanced control timer: 16-bit, 4 CAPCOM channels, 3 complementary outputs, dead-time insertion and flexible synchronization
    • 16-bit general purpose timer, with 3 CAPCOM channels (IC, OC or PWM)
    • 8-bit basic timer with 8-bit prescaler
    • Auto wakeup timer
    • Window watchdog, independent watchdog timers
  • Communications interfaces
    • UART with clock output for synchronous operation, Smartcard, IrDA, LIN master mode
    • SPI interface up to 8 Mbit/s
    • I2C interface up to 400 Kbit/s
  • Analog to digital converter (ADC)
    • 10-bit, ±1 LSB ADC with up to 5 multiplexed channels, scan mode and analog watchdog
  • I/Os
    • Up to 28 I/Os on a 32-pin package including 21 high sink outputs
    • Highly robust I/O design, immune against current injection
  • Development support
    • Embedded single wire interface module (SWIM) for fast on-chip programming and non intrusive debugging
STM8S005 Key Features
Key Features
  • Core
  • Memories
    • Memory density Flash/EEPROM:
      • Program memory: 32 Kbytes Flash; data retention 20 years at 55 °C after 100 cycles
    • RAM: 2 Kbytes
    • Power management:
    • Up to 37 external interrupts on 6 vectors
  • Timers
    • 2x16-bit general purpose timer, with 2+3 CAPCOM channels (IC, OC or PWM)
    • Auto wakeup timer
    • 10-bit, ±1 LSB ADC with up to 10 multiplexed channels, scan mode and analog watchdog
  • I/Os
    • Up to 38 I/Os on a 48-pin package including 16 high sink outputs
sinadz 发表于 2011-11-8 17:45 | 显示全部楼层
ST相当给力啊
mcuisp 发表于 2011-11-9 17:19 | 显示全部楼层
给力,价格肯定更给力
baidudz 发表于 2011-11-9 18:22 | 显示全部楼层
ST产品性价比相当高啊
 楼主| 香水城 发表于 2011-11-9 21:27 | 显示全部楼层
给力,价格肯定更给力
哈哈,彭总也要跟着给力哟,:handshake
秋天落叶 发表于 2011-11-9 23:08 | 显示全部楼层
彭总的产品也很给力啊
guanggaoren 发表于 2011-11-9 23:35 | 显示全部楼层
mcuisp 发表于 2011-11-10 06:57 | 显示全部楼层
必须的,呵呵:)
donkey89 发表于 2011-11-10 08:30 | 显示全部楼层
只看出电压变化了,其他还有哪里给力的?
dfsa 发表于 2011-11-10 19:06 | 显示全部楼层
给力的ST
videre 发表于 2011-11-10 21:46 | 显示全部楼层
ST发布新产品越来越快了
EEPROM小了,其他的好像和103/105差别不大
103F2卖到2块钱,003能便宜到啥程度啊
videre 发表于 2011-11-10 21:52 | 显示全部楼层
这次的数据手册,风格和以前不一样了
火箭球迷 发表于 2011-11-10 22:47 | 显示全部楼层
先看看,应该很不错
上官金虹 发表于 2011-11-11 08:05 | 显示全部楼层
003,005有啥特色,没看出来。
yinyangdianzi 发表于 2011-11-11 09:50 | 显示全部楼层
呵呵,,,早留意了。。。。。希望能更加便宜,更加稳定,更加容易!!
火箭球迷 发表于 2011-11-14 23:07 | 显示全部楼层
还有其他最新的产品没
cvdx526 发表于 2011-11-15 20:44 | 显示全部楼层
IAR支持新的器件吗?
无冕之王 发表于 2011-11-15 23:38 | 显示全部楼层
很给力的产品
认证:意法半导体(中国)投资有限公司
简介:STM32技术专家
596
