EPCS选型时,EP4SGX530 = 189,000,000 bits这个数据是哪来的?
4832|4
 楼主| tancm 发表于 2011-11-9 14:33 | 显示全部楼层 |阅读模式
EPCS选型时,看官方数据手册Serial Configuration Devices (EPCS1,EPCS4, EPCS16, EPCS64, and EPCS128)Data Sheet,有实例,很好,想照着做
Example 3–1. Compression Ratio Calculation
EPCS128 = 134,217,728 bits
Preliminary data indicates that compression typically reduces the configuration
bitstream size by 35% to 55%. We take the worst case that is 35% compression.
189,000,000 bits × 0.65 = 122,850,000 bits
It fits EPCS128 device.
结果再打开Stratix IV Device Handbook,怎么也找不到189,000,000 bits
这个数是怎么得到的?是不是通过某种方式计算得到的?
yizi0000 发表于 2011-11-22 23:01 | 显示全部楼层
Stratix IV Device Handbook第10章第3页 171,722,057
 楼主| tancm 发表于 2012-1-7 16:53 | 显示全部楼层
171,722,057和189,000,000有差别,189,000,000到底是怎么来的?
tear086 发表于 2012-1-29 15:10 | 显示全部楼层
查Altera产品目录 http://www.altera.com.cn/literature/sg/product-catalog.pdf
P8 EP4SGX530的Configuration file size (Mb) = 172 Mb = 172 x 1024 x 1024 = 180, 355, 072
然后使用压缩,可压缩掉35%,那么就需要65% x 172 Mb = 117, 230, 797 = 111.8 Mb,
然后EPCS128的容积为128Mb,于是用EPCS128就可以存储压缩后的EP4CGX570的配置文件。
