[CC2530] TDK Corporation 不平衡变压器针对 CC253x 进行了优化:CC2530TDKBA...
896|1
 楼主| dirtwillfly 发表于 2019-7-17 22:38 | 显示全部楼层 |阅读模式
描述
The CC2530EM reference design contains schematics and layout files for the CC2530 and contains one part from TDK Corporation interfacing the antenna (documented in AN104).
The TDK Corporation part realizes the balun-, filter- an impedance matching-function and is custom made to be operated with CC253x. CC254x and the CC85xx PurePath wireless family. The reference design demonstrates good techniques for CC2530 decoupling and RF layout. For optimum RF performance, the reference design should be copied accurately. This is a 2-layer reference design with a SMA antenna connector allowing operation with single ended 50 ohm antenna for easy connection to instruments for measurements.
 楼主| dirtwillfly 发表于 2019-7-17 22:39 | 显示全部楼层
TDK Corporation balun optimized for CC253x.pdf (917.53 KB, 下载次数: 0)
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1203
