[STM32H7] stm32f407 hal库如何启用HSI
1377|7
 楼主| a1986974 发表于 2019-7-31 13:18 | 显示全部楼层 |阅读模式
RCC_OscInitStructure.OscillatorType=RCC_OSCILLATORTYPE_HSI;    //时钟源为HSE
    RCC_OscInitStructure.HSEState=RCC_HSI_ON;                      //打开HSE
    RCC_OscInitStructure.PLL.PLLState=RCC_PLL_ON;//打开PLL
    RCC_OscInitStructure.PLL.PLLSource=RCC_PLLSOURCE_HSI;//PLL时钟源选择HSE
    RCC_OscInitStructure.PLL.PLLM=16; //主PLL和音频PLL分频系数(PLL之前的分频),取值范围:2~63.
    RCC_OscInitStructure.PLL.PLLN=plln; //主PLL倍频系数(PLL倍频),取值范围:64~432.
    RCC_OscInitStructure.PLL.PLLP=pllp; //系统时钟的主PLL分频系数(PLL之后的分频),取值范围:2,4,6,8.(仅限这4个值!)
    RCC_OscInitStructure.PLL.PLLQ=pllq; //USB/SDIO/随机数产生器等的主PLL分频系数(PLL之后的分频),取值范围:2~15.
    ret=HAL_RCC_OscConfig(&RCC_OscInitStructure);//初始化
不知为何老通不过这儿  if(ret!=HAL_OK) while(1);????请高手指点下
sky.sun.zz 发表于 2019-7-31 14:02 | 显示全部楼层
  1. void SystemClock_Config(void)
  3. RCC_OscInitTypeDef RCC_OscInitStruct;
  4.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  5. __HAL_RCC_PWR_CLK_ENABLE();
  6. __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  7. RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  8.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  9.   RCC_OscInitStruct.HSICalibrationValue = 16;
  10.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  11.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  12.   RCC_OscInitStruct.PLL.PLLM = 8;
  13.   RCC_OscInitStruct.PLL.PLLN = 168;
  14.   RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  15.   RCC_OscInitStruct.PLL.PLLQ = 4;
  16.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  17.   {
  18.     _Error_Handler(__FILE__, __LINE__);
  19.   }
  20. RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  21.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  22.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  23.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  24.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  25.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  26. if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
  27.   {
  28.     _Error_Handler(__FILE__, __LINE__);
  29.   }
  30. HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  31. HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  32. HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  33. }
hanzhen654 发表于 2019-7-31 14:29 | 显示全部楼层
板卡是哪个板卡?不通是没有道理的
 楼主| a1986974 发表于 2019-7-31 16:20 | 显示全部楼层
renzheshengui 发表于 2019-8-15 11:31 | 显示全部楼层
看看晶振起振了吗
wakayi 发表于 2019-8-15 11:38 | 显示全部楼层
用示波器看看晶振波形
xiaoqizi 发表于 2019-8-15 11:40 | 显示全部楼层
用的什么晶振啊
木木guainv 发表于 2019-8-15 12:01 | 显示全部楼层
不太清楚到底是什么问题
