[PIC®/AVR®/dsPIC®产品] 关于dsPIC33fj128GP804的位配置!【已解决】
1488|15
 楼主| ThinkIC 发表于 2019-8-3 00:23 | 显示全部楼层 |阅读模式
用Explorer 16/32开发板,官网DEMO程序无法进入Debug
麻烦哪位大神帮忙看看我的位配置有什么问题?
// FBS
#pragma config BWRP = WRPROTECT_OFF     // Boot Segment Write Protect (Boot Segment may be written)
#pragma config BSS = NO_FLASH           // Boot Segment Program Flash Code Protection (No Boot program Flash segment)
#pragma config RBS = NO_RAM             // Boot Segment RAM Protection (No Boot RAM)
// FSS
#pragma config SWRP = WRPROTECT_OFF     // Secure Segment Program Write Protect (Secure segment may be written)
#pragma config SSS = NO_FLASH           // Secure Segment Program Flash Code Protection (No Secure Segment)
#pragma config RSS = NO_RAM             // Secure Segment Data RAM Protection (No Secure RAM)
// FGS
#pragma config GWRP = OFF               // General Code Segment Write Protect (User program memory is not write-protected)
#pragma config GSS = OFF                // General Segment Code Protection (User program memory is not code-protected)
// FOSCSEL
#pragma config FNOSC = FRC              // Oscillator Mode (Internal Fast RC (FRC))
#pragma config IESO = OFF               // Internal External Switch Over Mode (Start-up device with user-selected oscillator source)
// FOSC
#pragma config POSCMD = XT           // Primary Oscillator Source (Primary Oscillator Disabled) 201900803
#pragma config OSCIOFNC = ON            // OSC2 Pin Function (OSC2 pin has digital I/O function)
#pragma config IOL1WAY = ON             // Peripheral Pin Select Configuration (Allow Only One Re-configuration)
#pragma config FCKSM = CSDCMD           // Clock Switching and Monitor (Both Clock Switching and Fail-Safe Clock Monitor are disabled)
// FWDT
#pragma config WDTPOST = PS32768        // Watchdog Timer Postscaler (1:32,768)
#pragma config WDTPRE = PR128           // WDT Prescaler (1:128)
#pragma config WINDIS = OFF             // Watchdog Timer Window (Watchdog Timer in Non-Window mode)
#pragma config FWDTEN = OFF             // Watchdog Timer Enable (Watchdog timer enabled/disabled by user software)
// FPOR
#pragma config FPWRT = PWR128           // POR Timer Value (128ms)
#pragma config ALTI2C = OFF             // Alternate I2C  pins (I2C mapped to SDA1/SCL1 pins)
// FICD
#pragma config ICS = PGD1               // Comm Channel Select (Communicate on PGC3/EMUC3 and PGD3/EMUD3)
#pragma config JTAGEN = OFF             // JTAG Port Enable (JTAG is Disabled)
 楼主| ThinkIC 发表于 2019-8-3 22:33 | 显示全部楼层
是因为今天是周末还是这个论坛根本没有人帮忙解决问题,大家都只是来看看?
小灵通2018 发表于 2019-8-5 11:11 | 显示全部楼层
热的要死,大家都纳凉去了
小灵通2018 发表于 2019-8-5 11:12 | 显示全部楼层
官方的DEMO工程吗,都无法debug?
如果官方的都不能,那没法了。。。是不是软件设置的问题,
zhuomuniao110 发表于 2019-8-6 00:02 | 显示全部楼层
https://www.microchip.com/wwwproducts/en/dsPIC33FJ128GP804
试试这里的例子。
你应该把那个例子连接发来,或者整个工程,只看你这一部分代码根本不知道什么。
zhuomuniao110 发表于 2019-8-6 00:03 | 显示全部楼层
如果是官方的demo,那更没法判断了。
alternate 发表于 2019-8-6 10:17 | 显示全部楼层
官网DEMO程序无法Debug,应该是环境配置问题
 楼主| ThinkIC 发表于 2019-8-6 21:27 | 显示全部楼层
试试这里的例子。
非常感谢,我先试试你给的例子。
 楼主| ThinkIC 发表于 2019-8-6 21:31 | 显示全部楼层
非常感谢,我先试试你给的例子。
附件中是官网demo请大神,帮忙分析下
 楼主| ThinkIC 发表于 2019-8-6 21:32 | 显示全部楼层
你应该把那个例子连接发来,或者整个工程,只看你这一部分代码根本不知道什么。 ...
附件中是官方demo,开发板是官方EXPLORER 16/32(部件号240001)
 楼主| ThinkIC 发表于 2019-8-6 22:33 | 显示全部楼层
感谢各位大神的帮助,debug模式已经能进去了,确实是配置位没有设置对,配置位进入debug模式
这一句写的很清楚,DEBUG模式要将PGD1改成PGD3。改了这个就能进了。
现在的问题是开发板上的LCD还是不能正常显示,我进入DEBUG模式也是想搞清这个问题。
谢谢各位给的思路,总算进了一步。
 楼主| ThinkIC 发表于 2019-8-7 22:42 | 显示全部楼层
Microchip的客服终于回应了,问题解决了,结帖!谢谢大家!
sanzi666 发表于 2019-8-20 14:48 | 显示全部楼层
dsPIC33EP16GS202
】这个有人用过吗,
aoyi 发表于 2019-9-13 10:20 | 显示全部楼层
恭喜楼主 解决问题
