[产品供应] PIC32 DM320004+DM320005开发板出售
2039|0
 楼主| fq1110 发表于 2011-11-12 14:08 | 显示全部楼层 |阅读模式
本人公司用的,结果突遇项目方案改变。故留着也是留着,便宜出售。有兴趣者可以提供实物照片。价格详谈。
DM320004
The PIC32 Ethernet Starter Kit provides the easiest and lowest cost method to experience 10/100 Ethernet development with PIC32. Combined with Microchip's[url=]free TCP/IP software[/url], your project will be running in no time. The PIC32 has an available CAN 2.0b peripheral and USB host/device/OTG.
The Ethernet Starter Kit has a form factor and expansion connector that are compatible with other PIC32 Starter Kits.
Box Contents:
PIC32 Ethernet Starter Board
Standard A to mini B cable for debugger
Standard A to micro B cable for USB application development
Ethernet cable
DM320005
The Multimedia Expansion Board is an integrated yet flexible solution for development of high impact User Interfaces. The board comes with a 3.2" Color TFT touch-screen display and interfaces to any PIC32 Starter kit allowing you to choose the device family that works best for you. Many Industrial and Consumer applications have a need for remote control of the application. The Multimedia Expansion Board comes with an onboard FCC certified WiFi module, and can accommodate the General Purpose, Ethernet, and USB PIC32 Starter Kits. Other features include a 24-bit stereo audio codec, three axis accelerometer, a joystick and, a MicroSD memory card slot. Simply connect any[url=]PIC32 starter kit[/url]connected to the Multimedia Expansion Board and you're ready to develop, program, and debug. Software for the Multimedia Expansion Board is contained within the[url=]Microchip Application Library[/url], including libraries for the joystick, accelerometer, CPLD, and more.
Box Contents:
Information Sheet with links to get started start card directing users to web based instructions for software download and installation. Note that no software is provided in the box.
**Starting with version 1.03 the MPLAB C Compiler for PIC32 Student Edition has no code size limit and full functionality for 60 days. After 60 days, optimization levels -O2, -O3, -Os are not available.
Board Features:
1. 3.2 inch (8.1 cm) QVGA touch screen display with backlight 2. Five user-controlled LEDs
3. Four-way joystick (S2)
4. Fire button (S1)
5. Headphone jack
6. Line output jack
7. Microphone input jack
8. Power LED
9. PICtail™ compatible expansion connector
1. Solomon Systech Graphics Controller (SSD1926)
2. microSD card slot.
3. Regulated 3.3V and 1.8V power supply for powering the board via a starter kit or 9-14V power supply
4. Accelerometer and temperature sensor (BMA150)
5. 24LC08 EEPROM.
6. SPI Flash (SST25VF016)
7. 24-bit audio codec (WM8731)
8. CPLD for SPI and Chip Select configuration
9. PIC32 starter kit connector
10. Integrated 802.11 wireless connectivity
