`define SCAN module key_scan( clk , rst_n , key_col, //键盘列输入 key_row, //键盘行输出 key_num, //指示哪一个按键按下,用0~15指示 key_vld //按下有效指示信号,其为1表示按下一次。 ); parameter KEY_W = 4 ; parameter COL = 0 ; parameter ROW = 1 ; parameter DLY = 2 ; parameter FIN = 3 ; parameter COL_CNT = 16; parameter TIME_20MS= 1000000; //输入信号定义 input clk ; input rst_n ; input [3:0] key_col; //输出信号定义 output key_vld; output[3:0] key_num; output[KEY_W-1:0] key_row; //输出信号reg定义 reg [3:0] key_num; reg [KEY_W-1:0] key_row; reg key_vld; reg [ 3:0] key_col_ff0 ; reg [ 3:0] key_col_ff1 ; reg [ 1:0] key_col_get ; reg shake_flag ; reg shake_flag_ff0; reg [ 3:0] state_c ; reg [19:0] shake_cnt ; reg [ 3:0] state_n ; reg [ 1:0] row_index ; reg [15:0] row_cnt ; reg [ 2:0] x ; always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin key_col_ff0 <= 4'b1111; key_col_ff1 <= 4'b1111; end else begin key_col_ff0 <= key_col ; key_col_ff1 <= key_col_ff0; end end always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin shake_cnt <= 0; end else if(add_shake_cnt)begin if(end_shake_cnt) shake_cnt <= 0; else shake_cnt <= shake_cnt + 1; end else begin shake_cnt <= 0; end end assign add_shake_cnt = key_col_ff1!=4'hf && shake_flag==0; assign end_shake_cnt = add_shake_cnt && shake_cnt==TIME_20MS-1; always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin shake_flag <= 0; end else if(end_shake_cnt) begin shake_flag <= 1'b1; end else if(key_col_ff1==4'hf) begin shake_flag <= 1'b0; end end `ifdef SCAN always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin state_c <= COL; end else begin state_c <= state_n; end end always @(*)begin case(state_c) COL: begin if(col2row_start)begin state_n = ROW; end else begin state_n = state_c; end end ROW: begin if(row2dly_start)begin state_n = DLY; end else begin state_n = state_c; end end DLY : begin if(dly2fin_start)begin state_n = FIN; end else begin state_n = state_c; end end FIN: begin if(fin2col_start)begin state_n = COL; end else begin state_n = state_c; end end default: state_n = COL; endcase end assign col2row_start = state_c==COL && end_shake_cnt; assign row2dly_start = state_c==ROW && end_row_index; assign dly2fin_start = state_c==DLY && end_row_index; assign fin2col_start = state_c==FIN && key_col_ff1==4'hf; always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin key_row <= 4'b0; end else if(state_c==ROW)begin key_row <= ~(1'b1 << row_index); end else begin key_row <= 4'b0; end end always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin row_cnt <= 0; end else if(add_row_cnt) begin if(end_row_cnt) row_cnt <= 0; else row_cnt <= row_cnt + 1; end end assign add_row_cnt = state_c==ROW || state_c==DLY; assign end_row_cnt = add_row_cnt && row_cnt==COL_CNT-1; always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin row_index <= 0; end else if(add_row_index) begin if(end_row_index) row_index <= 0; else row_index <= row_index + 1; end end assign add_row_index = end_row_cnt; assign end_row_index = add_row_index && row_index==x-1; always @(*)begin if(state_c==ROW) x = 4; else x = 1; end always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin key_col_get <= 0; end else if(col2row_start) begin if(key_col_ff1==4'b1110) key_col_get <= 0; else if(key_col_ff1==4'b1101) key_col_get <= 1; else if(key_col_ff1==4'b1011) key_col_get <= 2; else key_col_get <= 3; end end always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin key_num <= 0; end else if(state_c==ROW && end_row_cnt)begin key_num <= {row_index,key_col_get}; end else begin key_num <= 0; end end always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin key_vld <= 1'b0; end else if(state_c==ROW && end_row_cnt && key_col_ff1[key_col_get]==1'b0)begin key_vld <= 1'b1; end else begin key_vld <= 1'b0; end end `else always @(posedge clk or negedge rst_n)begin if(rst_n==1'b0)begin key_vld <= 0; end else begin key_vld <= end_shake_cnt; end end always @(*)begin key_num = 0; end `endif endmodule
