为什么不能直接对端口引脚直接赋值???
10030|8
 楼主| wanli518happy 发表于 2011-11-16 23:58 | 显示全部楼层 |阅读模式
52中为什么我对端口直接赋值会报错??
void main()
  P1^0= 0;
  while(1);
而改成这样又可以了呢?  led和P1^0不就是等价的么???求解。。。谢谢
sbit led = P1^0;
void main()
  led  = 0;
  while(1);
yuandm1 发表于 2011-11-17 07:38 | 显示全部楼层
原来也遇到过这种情况,没问为啥就过去了。帮顶
HWM 发表于 2011-11-17 07:49 | 显示全部楼层
re LZ:
“P1^0”只是个常数,表示寄存器P0的0位的位地址值。而
sbit led = P1^0;
才真正地定义了一个位变量。有了变量才能对此赋值。
ayb_ice 发表于 2011-11-17 08:04 | 显示全部楼层
mugenwon 发表于 2011-11-17 08:21 | 显示全部楼层
3楼正解。和编译器也有关。
micropower 发表于 2011-11-17 08:26 | 显示全部楼层
你的程序都没对P1^0定义,人家编译器都不知道是干什么的。
而像P0 P1 P2这些都需要定义的,但你所调用的头文件里已经定义好了,所以不需要定义。如果你的程序没包括这个头文件。编译器照样认不出P1是什么。
micropower 发表于 2011-11-17 08:27 | 显示全部楼层
wurongyan 发表于 2012-5-24 17:22 | 显示全部楼层
REG52.H
Header file for generic 80C52 and 80C32 microcontroller.
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __REG52_H__
#define __REG52_H__
/*  BYTE Registers  */
sfr P0    = 0x80;
sfr P1    = 0x90;
sfr P2    = 0xA0;
sfr P3    = 0xB0;
sfr PSW   = 0xD0;
sfr ACC   = 0xE0;
sfr B     = 0xF0;
sfr SP    = 0x81;
sfr DPL   = 0x82;
sfr DPH   = 0x83;
sfr PCON  = 0x87;
sfr TCON  = 0x88;
sfr TMOD  = 0x89;
sfr TL0   = 0x8A;
sfr TL1   = 0x8B;
sfr TH0   = 0x8C;
sfr TH1   = 0x8D;
sfr IE    = 0xA8;
sfr IP    = 0xB8;
sfr SCON  = 0x98;
sfr SBUF  = 0x99;
/*  8052 Extensions  */
sfr T2CON  = 0xC8;
sfr RCAP2L = 0xCA;
sfr RCAP2H = 0xCB;
sfr TL2    = 0xCC;
sfr TH2    = 0xCD;
/*  BIT Registers  */
/*  PSW  */
sbit CY    = PSW^7;
sbit AC    = PSW^6;
sbit F0    = PSW^5;
sbit RS1   = PSW^4;
sbit RS0   = PSW^3;
sbit OV    = PSW^2;
sbit P     = PSW^0; //8052 only
/*  TCON  */
sbit TF1   = TCON^7;
sbit TR1   = TCON^6;
sbit TF0   = TCON^5;
sbit TR0   = TCON^4;
sbit IE1   = TCON^3;
sbit IT1   = TCON^2;
sbit IE0   = TCON^1;
sbit IT0   = TCON^0;
/*  IE  */
sbit EA    = IE^7;
sbit ET2   = IE^5; //8052 only
sbit ES    = IE^4;
sbit ET1   = IE^3;
sbit EX1   = IE^2;
sbit ET0   = IE^1;
sbit EX0   = IE^0;
/*  IP  */
sbit PT2   = IP^5;
sbit PS    = IP^4;
sbit PT1   = IP^3;
sbit PX1   = IP^2;
sbit PT0   = IP^1;
sbit PX0   = IP^0;
/*  P3  */
sbit RD    = P3^7;
sbit WR    = P3^6;
sbit T1    = P3^5;
sbit T0    = P3^4;
sbit INT1  = P3^3;
sbit INT0  = P3^2;
sbit TXD   = P3^1;
sbit RXD   = P3^0;
/*  SCON  */
sbit SM0   = SCON^7;
sbit SM1   = SCON^6;
sbit SM2   = SCON^5;
sbit REN   = SCON^4;
sbit TB8   = SCON^3;
sbit RB8   = SCON^2;
sbit TI    = SCON^1;
sbit RI    = SCON^0;
/*  P1  */
sbit T2EX  = P1^1; // 8052 only
sbit T2    = P1^0; // 8052 only
/*  T2CON  */
sbit TF2    = T2CON^7;
sbit EXF2   = T2CON^6;
sbit RCLK   = T2CON^5;
sbit TCLK   = T2CON^4;
sbit EXEN2  = T2CON^3;
sbit TR2    = T2CON^2;
sbit C_T2   = T2CON^1;
sbit CP_RL2 = T2CON^0;
#endif
这是REG52.H头文件定义,里面没有P^0之类的定义,所以编译器会把它当做是非法字符,任何合法的标识符都要先定义再使用!
开头不就是  发表于 2020-2-16 16:28
