Kernel configuration is invalid.
5900|2
 楼主| caoqing1314 发表于 2011-11-19 12:50 | 显示全部楼层 |阅读模式
这是我.c文件
#include<linux/init.h>
#include<linux/module.h>
static int  __init hello_init(void)
printk(KERN_INFO "Hello World enter\n");
return 0;
static void  __exit hello_exit(void)
printk(KERN_INFO "Hello World exit\n");
module_init(hello_init);
module_exit(hello_exit);
MODULE_AUTHOR("caoxing");
MODULE_LICENSE("Dual BSD/GPL");
MODULE_DESCRIPTION("A simple Hello World Module");
MODULE_ALIAS("a simple module");
这是我的makefile
CROSS_COMPILE = arm-linux-
CC              = $(CROSS_COMPILE)gcc
obj-m :=hello.o
KDIR :=/opt/FriendlyARM/mini6410/linux/linux-2.6.38
PWD :=$(shell pwd)
all:
$(MAKE) -C $(KDIR) SUBDIRS=$(PWD) modules
@rm -rf *.mod.*
@rm -rf .*.cmd
@rm -rf *.o
@rm -rf Module.*
clean:
rm -rf *.ko
但是make后出现这种问题,各位大侠帮助呀!!!!!!!!!!
file:///D:/下载/QQ/Users/769181464/Image/25QTE}4Y4RCHYL4IAN8HA6G.jpg
 楼主| caoqing1314 发表于 2011-11-19 12:53 | 显示全部楼层
那个截图不能显示,补充如下,我遇到的问题:
ERROR: Kernel configuration is invalid.
         include/generated/autoconf.h or include/config/auto.conf are missing.
         Run 'make oldconfig && make prepare' on kernel src to fix it.
  WARNING: Symbol version dump /opt/FriendlyARM/mini6410/linux/linux-2.6.38/Module.symvers
           is missing; modules will have no dependencies and modversions.
  CC [M]  /home/caoxing/hello/hello.o
/bin/sh: arm-linux-gcc: command not found
make[2]: *** [/home/caoxing/hello/hello.o] 错误 127
make[1]: *** [_module_/home/caoxing/hello] 错误 2
make[1]: Leaving directory `/opt/FriendlyARM/mini6410/linux/linux-2.6.38'
make: *** [all] 错误 2
 楼主| caoqing1314 发表于 2011-11-19 22:08 | 显示全部楼层
不麻烦大家了,我已经解决了。:)
