| #include <reg52.h> #define Segment P2
 #define sl P0
 unsigned char cnt;      //定时1s计数
 unsigned char d[];     //对应数码管的各位
 unsigned char level;    //档位
 unsigned int tN;        //不同档位计时值
 unsigned int fCnt;      //脉冲下降沿次数
 unsigned int regCnt;    //脉冲次数暂存
 unsigned int pCnt;      //频率显示
 unsigned char Num[10]={0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
 void Delay(unsigned int DelayTime)
 while(DelayTime--) ;
 void disp()
 {  if(level==0)                 //B位档
 d[3]=0;
 d[2]=pCnt/100;
 d[1]=(pCnt%100)/10;
 d[0]=pCnt%10;
 sl=0xfe;Delay(1);Segment=Num[d[3]];Delay(300);
 sl=0xfd;Delay(1);Segment=Num[d[2]];Delay(300);
 sl=0xfb;Delay(1);Segment=Num[d[1]];Delay(300);
 sl=0xf7;Delay(1);Segment=Num[d[0]];Delay(300);
 else if(level==1)
 d[3]=pCnt/1000;
 d[2]=(pCnt%1000)/100;
 d[1]=(pCnt%100)/10;
 d[0]=pCnt%10;
 sl=0xfb;Delay(1);Segment=Num[d[1]]+0x80;Delay(300);  //带小数点
 else if(level==2)
 d[3]=pCnt/1000;
 d[1]=(pCnt%100)/10;
 d[0]=pCnt%10;
 else
 { d[3]=0;
 d[2]=0;
 d[1]=0;
 d[0]=0;
 void intial()
 clear=1;
 addr=1;                 //分频器初始化
 tN=20;                   //档位初始化为Hz档
 level=0;
 ledM=1;                  //显示Hz档
 ledK=1;
 ledB=0;
 TMOD=0x61;      //定时器0,工作方式1,计数器1,工作方式2(8位自动重装)
 //开定时器0中断
 ET0=1;       //定时器0允许
 TR1=1;       //开计数器1中断
 ET1=1;         //允许计数器1中断
 EA=1;                    //总中断允许
 void main()
 intial();
 while(1)
 disp();
 void timer0() interrupt 1
 cnt++;
 if(cnt==tN)
 regCnt=fCnt;          //更新显示
 fCnt=0;               //频率计数清零
 clear=0;              //硬件分频器清零
 clear=1;
 if(level==0)          //档位切换
 pCnt=regCnt;
 if(regCnt>999)
 pCnt=0;       //显示清零
 else if(level==1)
 if(regCnt<1)
 level=0;
 tN=20;       //定时1s
 addr2=1;     //不分频
 else if(regCnt<1000) //KHz档
 level=1;
 tN=1;               //定时50ms
 addr2=0;            //硬件分频处理
 TH1=0xfb;           //50分频  256-5
 TL1=0xfb;           //256-5
 pCnt=regCnt*10;     //换算成相应的显示:f=regCnt*100
 ledM=1;             //显示KHz档
 ledK=0;
 ledB=1;
 else
 level=2;
 //显示MHz档
 ledK=1;
 ledB=1;
 else if(level==2)
 if(regCnt<500)       //KHz档
 level=1;
 tN=1;               //定时50ms
 addr2=0;            //分频
 //显示KHz档
 ledK=0;
 ledB=1;
 else if(regCnt<5000)
 level=2;
 tN=1;               //定时50ms
 addr2=0;            //分频
 TH1=0xf6;           //100分频 256-10
 TL1=0xf6;           //256-10
 ledB=1;
 else
 level=3;            //超出范围
 ledM=1;             //全灭
 ledK=1;
 ledB=1;
 ET1=1;                      //恢复外部计数1
 TR1=1;
 TH0=0x3c;                       //(65536-50000)/256;
 TL0=0xb0;                       //(65536-50000)%256;
 void enterFre() interrupt 3         //外部频率输入
 fCnt++;
