数据采集
337|0
·        4 channel Data Loggerdesigned for easy setup and trouble free operation. It includes [tr]freeeasy to use software.
·        [tr]Mix and Match a Wide Range of Sensors[tr] including [tr]Temperature, [tr]Pressure, [tr]Humidity, [tr]ACcurrent, [tr]DCCurrent, [tr]ACVoltage, [tr]DCVoltage, [tr]Light, [tr]ProcessSignals[tr] andmore. stocks over [tr]70compatible sensors[tr].Plus,  can directly read resistances, 0-5Vdc signals and contact closures.
·        [tr]Multi-year Battery Life [tr]withany combination of sensors[tr].All sensors are powered from the logger's user-replaceable battery.
·        [tr]Data Logging Applications
·        [tr]Pressure
·        [tr]Temperature
·        [tr]ACCurrent
·        [tr]Temperatureand Relative Humidity
·        [tr]ACand DC Voltage
·        Four multi-purpose inputs; mix and match Pace sensors in anycombination.
·        Each input will also read resistance, 0-5 Vdc or acontact closure.
·        Data retention of over 200 years with no power.
·        High accuracy, up to +/-0.15°C and +/-0.25% F.S. with nocalibration.
·        Wide operating temperature range -40°C to 60°C (-40°F to140°F).
·        Certificate of Validation, traceable to NIST, includedwith each unit.
·        Long battery life, runs unattended for over 2 years(including sensors) without external power.
·        Optional Pulse Module for tipping bucket rain gage,gas and water meters, and kWH meters.
·        Optional Scaling Module for±5, 0-10, 0-20, 0-30, 0-60 Vdc and 4-20 ma signals.
·        Optional Thermocouple / Millivolt Modules forthermocouple or millivolt signal.
·        Easy to use Windows software (fullversion available for free download) for logger setup, data transfer, graphingand data export.
·        CE Marked.、
发新帖
