LM3S811 使用心得二 之超声波测距(含液晶显示)
5831|16
 楼主| nwx8899 发表于 2011-11-20 13:00 | 显示全部楼层 |阅读模式
LM3S811控制超声波传感器,
计算出到障碍物的距离,并通过5110lcd显示出来(这里关于5110的显示程序是效仿楼上 baixichi 兄的心得)。主要就把超声波测距的程序贴一下:
//main.c
#include "LM3S811.h"
#include "uart1.h"
#include "uart0.h"
#include <stdio.h>
/*****************超声波数据结构声明**********************/
typedef struct suWaveData
uint8 flag;
uint8 tempcmd[4];
   //温度
uint8 tempdata[2];
uint8 distcmd[4];
   //距离
uint8 distdata[2];
}suWave_t;
suWave_t suWave1={0x00,0x11,0x00,0x00,0x11,0x00,0x00,
  0x22,0x55,0x00,0x77,0x00,0x00}; //初始化超声波数据变量
/******************函数声明*********************************/
static void init_LM3S811(void);
static void delay(uint16 dly);
void   process_udata(suWave_t *pfile);
functionmain 函数
input:    null
output:   null
author:  gyk
data
  2011_11_18
int main(void)
init_LM3S811();
init_UART0(9600,2);
init_UART1(9600,3);
IntMasterEnable();
send_str_UART1("System initialization sucessful!!!\n");
send_str_UART1("Waiting for the data from URM37V3.2...\n");
for(;;)
send_UART0(suWave1.tempcmd,4);
delay(100);
send_UART0(suWave1.distcmd,4);
delay(100);
process_udata(&suWave1);
delay(5000);
function:初始化
input:    null
output:   null
author:  gyk
data
  2011_11_18
SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN|SYSCTL_XTAL_6MHZ);
function:延时
input:    dly
output:   null
author:  gyk
data
  2011_11_18
uint16 i;
for(;dly>0;dly--)
for(i=0;i<100;i++);
function: 超声波数据处理
input:    null
output:   null
author:  gyk
data
  2011_11_18
uint8 buffer[30];
uint16 tmp;
fp32   ftmp;
if(pfile->flag&&0x01)
if((pfile->tempdata[0]==0xFF)&&(pfile->tempdata[1]==0xFF))
send_str_UART1("Temperature: invalid data!\n");
return;
if((pfile->tempdata[0]&0xF0)==0xF0)
tmp=(uint16)(pfile->tempdata[0]&0xF0);
tmp<<=8;
tmp|=(uint16)pfile->tempdata[1];
ftmp=(fp32)tmp*0.1;
send_UART1(buffer,sprintf((char *)buffer,"temerature:  -%f\n",ftmp));
if((pfile->tempdata[0]&0xF0)==0x00)
tmp=(uint16)(pfile->tempdata[0]);
tmp<<=8;
ftmp=(fp32)tmp*0.1;
send_UART1(buffer,sprintf((char *)buffer,"temerature:  %f\n",ftmp));
pfile->flag&=0xFE;
if(pfile->flag&0x02)
tmp=(uint16)pfile->distdata[0];
tmp<<=8;
tmp|=pfile->distdata[1];
if(tmp==0xFFFF)
send_str_UART1("distance: invalid data!\n");
return;
send_UART1(buffer,sprintf((char *)buffer,"distance:  %f\n",tmp));
pfile->flag&=0xFD;
function: interrupt
input:    null
output:   null
author:  gyk
data
  2011_11_18
void uart0_isr(void)
uint8 ch;
unsigned long ulStatus;
ulStatus=UARTIntStatus(UART0_BASE,true);
UARTIntClear(UART0_BASE,ulStatus);
if((ulStatus&UART_INT_RT)||(ulStatus&UART_INT_RX))
ch=UARTCharGet(UART0_BASE);
if(ch==0x11)
suWave1.tempdata[0]=UARTCharGet(UART0_BASE);
suWave1.tempdata[1]=UARTCharGet(UART0_BASE);
suWave1.flag|=0x01;
if(ch==0x022)
suWave1.distdata[0]=UARTCharGet(UART0_BASE);
suWave1.distdata[1]=UARTCharGet(UART0_BASE);
suWave1.flag|=0x02;
//uart0.h
#ifndef  _UART0_H_
#define  _UART0_H_
extern uint8 init_UART0(uint32 baudrate,uint8 prio);
extern void  send_UART0(uint8 *pbuffer,uint16 size);
extern void recv_UART0(void);
extern void  send_str_UART0(uint8 *pstr);
#endif
//uart1.h
#ifndef  _UART1_H_
#define  _UART1_H_
extern uint8 init_UART1(uint32 baudrate,uint8 prio);
extern void  send_UART1(uint8 *pbuffer,uint16 size);
extern void recv_UART1(void);
extern void  send_str_UART1(uint8 *pstr);
#endif
//uart0.c
#include"LM3S811.h"
function: 初始化串口0
input:    波特率,ISR优先级
output:   fasle失败,true成功
author:  gyk
data
  2011_11_18
if(baudrate>15200)
return FALSE;
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
GPIOPinTypeUART(GPIO_PORTA_BASE,GPIO_PIN_0|GPIO_PIN_1);
UARTConfigSetExpClk(UART0_BASE,SysCtlClockGet(),baudrate,(UART_CONFIG_WLEN_8|UART_CONFIG_STOP_ONE|UART_CONFIG_PAR_NONE));
UARTFIFOLevelSet(UART0_BASE,UART_FIFO_TX1_8,UART_FIFO_RX4_8);
    UARTIntEnable(UART0_BASE,UART_INT_RX|UART_INT_RT);
IntEnable(INT_UART0);
IntPrioritySet(INT_UART0,prio);
UARTEnable(UART0_BASE);
return TURE;
function: 串口0发送数据
input:    缓冲区大小,数据大小
output:   null
author:  gyk
data
  2011_11_18
uint16 i;
for(i=0;i<size;i++)
UARTCharPut(UART0_BASE,pbuffer);
while(UARTBusy(UART0_BASE));
function: 串口0发送字符串
input:    字符串指针
output:   null
author:  gyk
data
  2011_11_18
while(*pstr!='\0')
UARTCharPut(UART0_BASE,*pstr++);
//uart1.c
#include"LM3S811.h"
function: 初始化串口1
input:    波特率,ISR优先级
author:  gyk
data
  2011_11_18
if(baudrate>15200)
return FALSE;
(void)prio;
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART1);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
GPIOPinTypeUART(GPIO_PORTD_BASE,GPIO_PIN_2|GPIO_PIN_3);
UARTConfigSetExpClk(UART1_BASE,SysCtlClockGet(),baudrate,(UART_CONFIG_WLEN_8|UART_CONFIG_STOP_ONE|UART_CONFIG_PAR_NONE));
UARTFIFOLevelSet(UART1_BASE,UART_FIFO_TX1_8,UART_FIFO_RX4_8);
UARTEnable(UART1_BASE);
return TURE;
function: 串口1发送数据
input:    缓冲区大小,数据大小
output:   null
author:  gyk
data
  2011_11_18
uint16 i;
for(i=0;i<size;i++)
UARTCharPut(UART1_BASE,pbuffer);
while(UARTBusy(UART1_BASE));
function: 串口1发送字符串
input:    字符串指针
output:   null
author:  gyk
data
  2011_11_18
while(*pstr!='\0')
UARTCharPut(UART1_BASE,*pstr++);
//lcd.c  lcd.h
//仿照baixichi
再贴张照片吧
 楼主| nwx8899 发表于 2011-11-20 13:01 | 显示全部楼层
1# nwx8899
超出范围了
 楼主| nwx8899 发表于 2011-11-20 13:02 | 显示全部楼层
1# nwx8899
//关于定时器的使用
void  SysClockInit_40M(void)
SysCtlLDOSet( SYSCTL_LDO_2_75V);
    SysCtlDelay(SysCtlClockGet()/3000);
                                                     //延时1ms,稳定芯片用
SysCtlClockSet(SYSCTL_SYSDIV_5 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_6MHZ);   //5分频,PLL设置时钟为40M
//延时1ms,稳定芯片用
SysCtlLDOSet( SYSCTL_LDO_2_50V);
void Timer0A_ISR(void)
     TimerIntClear(TIMER0_BASE,TIMER_TIMA_TIMEOUT );
//清除中断源
     counter++;
//处理过程
     void TimerEnable(TIMER0_BASE, Timer_A);
             //使能定时器
int main(void)
    SysClockInit_40M();
SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);           //使能定时器0
// 使能PA端口
    GPIOPinTypeGPIOInput(GPIO_PORTA_BASE, GPIO_PIN_0);
// 设置PA0为超声波的echo管脚
GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_1 );
// 设置PA1为超声波的trig管脚
/*************************************关于定时器中断的设置**********************************/
    TimerConfigure(TIMER0_BASE, TIMER_CFG_16_BIT_PAIR|TIMER_CFG_A_PERIODIC);   //配置成16位周期定时器,使用定时器A
    void TimerLoadSet(TIMER0_BASE,  Timer_A, unsigned long ulValue);
   //设置定时器初始值
void TimerIntRegister(TIMER0_BASE,  Timer_A,void Timer0A_ISR(void));
   //声明定时器A的中断处理函数
                                   //使能定时器
void TimerIntEnable(TIMER0_BASE, TIMER_TIMA_TIMEOUT);
                   //使能中断,设置为定时器A的溢出中断
GPIOPinWrite(GPIO_PORTC_BASE,GPIO_PIN_1,GPIO_PIN_1);
GPIOPinRead(GPIO_PORTC_BASE, GPIO_PIN_0);
while(1)
//trig口设置高电平信号,启动超声波传感器
        SysCtlDelay(SysCtlClockGet()/3000/50);
//高电平持续 20US
GPIOPinWrite(GPIO_PORTC_BASE,GPIO_PIN_1,~GPIO_PIN_1);
//trig口置低电平
flag=0;
//设置标志位,方便对超声波传感器的控制
while(flag==0)
if(GPIOPinRead(GPIO_PORTA_BASE, GPIO_PIN_0)==0)
   { SysCtlIntDisable(TIMERA_BASE, TIMER_TIMA_TIMEOUT);     //关闭中断
  distance=counter;
  counter=0;
  flag=1;
  while(GPIOPinRead(GPIO_PORTA_BASE, GPIO_PIN_0)==0);    //等待超声波的echo端口转变为高电平,表示一次测距结束
fengzhongfeiwu 发表于 2011-11-20 19:19 | 显示全部楼层
2# nwx8899
图不错
 楼主| nwx8899 发表于 2011-11-20 21:07 | 显示全部楼层
4# fengzhongfeiwu  分全给你了
shuaijing 发表于 2011-11-21 21:48 | 显示全部楼层
好难哦,分享了
 楼主| nwx8899 发表于 2011-11-23 12:36 | 显示全部楼层
6# shuaijing :handshake
baixichi 发表于 2011-11-29 11:09 | 显示全部楼层
这个超声波的模块之前见朋友用过,如果用作蔽障的话,勉强可以,不过仍有很多盲区。如果想做测距,建议买一个精确点的模块。。。
tianm 发表于 2011-11-29 12:48 | 显示全部楼层
拍个整体就好了 包括被测距离的物体
 楼主| nwx8899 发表于 2011-11-29 13:01 | 显示全部楼层
9# jingshuai 参考书的
10# tianm 手在前面,传感器在边上
fengzhongfeiwu 发表于 2011-12-14 11:50 | 显示全部楼层
 楼主| nwx8899 发表于 2011-12-14 16:44 | 显示全部楼层
sqcumt123 发表于 2011-12-20 15:13 | 显示全部楼层
好复杂啊,基本没怎么看懂,得好好学习一下
勤勉务实 发表于 2012-5-13 22:11 | 显示全部楼层
新手学习了!谢谢!
拿起书本 发表于 2012-5-13 22:23 | 显示全部楼层
我前两年也搞过,不过这东西放到室外需要作的处理太多了,实验室的东西不能用。
jxmzzr 发表于 2012-5-13 22:58 | 显示全部楼层
超声波物位移还算不错,呵呵。楼主也的也不错。
个人签名: 宁静致远
61
