- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * $Revision: 5 $
- * $Date: 15/07/02 11:18a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Demonstrate how to use timer2 capture event to capture timer2 counter value.
- * @note
- * Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NUC123.h"
- #define HCLK_CLOCK 72000000
- /* Global Interface Variables Declarations */
- volatile uint32_t g_au32TMRINTCount[4] = {0};
- * @brief Timer0 IRQ
- * @param None
- * [url=home.php?mod=space&uid=266161]@return[/url] None
- * [url=home.php?mod=space&uid=1543424]@Details[/url] The Timer0 default IRQ, declared in startup_NUC123.s.
- void TMR0_IRQHandler(void)
- /* Clear Timer0 time-out interrupt flag */
- TIMER_ClearIntFlag(TIMER0);
- g_au32TMRINTCount[0]++;
- * @brief Timer1 IRQ
- * @param None
- * @return None
- * @details The Timer1 default IRQ, declared in startup_NUC123.s.
- void TMR1_IRQHandler(void)
- /* Clear Timer1 time-out interrupt flag */
- TIMER_GetIntFlag(TIMER1);
- g_au32TMRINTCount[1]++;
- * @brief Timer2 IRQ
- * @param None
- * @return None
- * @details The Timer2 default IRQ, declared in startup_NUC123.s.
- void TMR2_IRQHandler(void)
- if(TIMER_GetCaptureIntFlag(TIMER2) == 1)
- /* Clear Timer2 capture interrupt flag */
- TIMER_ClearCaptureIntFlag(TIMER2);
- g_au32TMRINTCount[2]++;
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable IRC22M clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for IRC22M clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to HIRC */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable XT1_OUT(PF.0) and XT1_IN(PF.1) */
- SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
- /* Enable external 12 MHz XTAL */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for clock ready */
- while(!CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk));
- /* Set core clock as HCLK_CLOCK */
- CLK_SetCoreClock(HCLK_CLOCK);
- /* Enable peripheral clock */
- CLK_EnableModuleClock(UART0_MODULE);
- CLK_EnableModuleClock(TMR0_MODULE);
- CLK_EnableModuleClock(TMR1_MODULE);
- CLK_EnableModuleClock(TMR2_MODULE);
- /* Peripheral clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
- CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0_S_HXT, 0);
- CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1_S_HXT, 0);
- CLK_SetModuleClock(TMR2_MODULE, CLK_CLKSEL1_TMR2_S_HCLK, 0);
- /* Init I/O Multi-function */
- /* Set PB multi-function pins for UART0 RXD, TXD, TM0, TM1, TM2 and TM2_EXT */
- SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD |
- SYS_GPB_MFP_PB8_TM0 | SYS_GPB_MFP_PB9_TM1 | SYS_GPB_MFP_PB10_TM2 |
- SYS_GPB_MFP_PB2_TM2_EXT;
- SYS->ALT_MFP = SYS_ALT_MFP_PB2_TM2_EXT;
- void UART0_Init(void)
- /* Init UART */
- /* Reset IP */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* MAIN function */
- int main(void)
- volatile uint32_t u32InitCount, u32TimeoutCount;
- uint32_t au32CAPValus[10];;
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, peripheral clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
- printf("+---------------------------------------------------+\n");
- printf("| Timer External Capture Function Sample Code |\n");
- printf("+---------------------------------------------------+\n\n");
- printf("# Timer Settings:\n");
- printf(" Timer0: Clock source is 12 MHz; Toggle-output mode and frequency is 500 Hz.\n");
- printf(" Timer1: Clock source is 12 MHz; Toggle-output mode and frequency is 1 Hz.\n");
- printf(" Timer2: Clock source is HCLK(72 MHz); Continuous counting mode; TCMP is 0xFFFFFF;\n");
- printf(" Counter pin enable; Capture pin and capture interrupt enable;\n");
- printf("# Generate 500 Hz frequency from TM0(PB.8) and connect TM0 pin to Timer2 counter pin(PB.10).\n");
- printf("# Generate 1 Hz frequency from TM1(PB.9) and connect TM1 pin to TM2_EXT(PB.2) capture pin.\n");
- printf("# Get 500 event counts from Timer2 counter pin when each TM2_EXT pin interrupt occurred.\n\n");
- /* Initial Timer0 and Timer1 default setting */
- TIMER_Open(TIMER0, TIMER_TOGGLE_MODE, 1000);
- TIMER_Open(TIMER1, TIMER_TOGGLE_MODE, 2);
- /* Initial Timer2 default setting */
- TIMER_Open(TIMER2, TIMER_CONTINUOUS_MODE, 1);
- /* Configure Timer2 setting for external counter input and capture function */
- TIMER_SET_PRESCALE_VALUE(TIMER2, 0);
- TIMER_SET_CMP_VALUE(TIMER2, 0xFFFFFF);
- TIMER_EnableEventCounter(TIMER2, TIMER_COUNTER_FALLING_EDGE);
- TIMER_EnableCapture(TIMER2, TIMER_CAPTURE_FREE_COUNTING_MODE, TIMER_CAPTURE_FALLING_EDGE);
- TIMER_EnableCaptureInt(TIMER2);
- /* Enable Timer2 NVIC */
- NVIC_EnableIRQ(TMR2_IRQn);
- /* Clear Timer2 interrupt counts to 0 */
- u32InitCount = g_au32TMRINTCount[2] = 0;
- /* Start Timer0, Timer1 and Timer2 counting */
- TIMER_Start(TIMER0);
- TIMER_Start(TIMER1);
- TIMER_Start(TIMER2);
- /* Check TM2_EXT interrupt counts */
- u32TimeoutCount = 0;
- while(g_au32TMRINTCount[2] <= 10)
- if(g_au32TMRINTCount[2] != u32InitCount)
- au32CAPValus[u32InitCount] = TIMER_GetCaptureData(TIMER2);
- printf("[%2d] - %4d\n", g_au32TMRINTCount[2], au32CAPValus[u32InitCount]);
- if(u32InitCount > 1)
- if((au32CAPValus[u32InitCount] - au32CAPValus[u32InitCount - 1]) != 500)
- printf("*** FAIL ***\n");
- while(1);
- u32InitCount = g_au32TMRINTCount[2];
- if(u32TimeoutCount++ > SystemCoreClock / 2)
- printf("Timer2 capture event time-out.\n");
- while(1);
- /* Stop Timer0, Timer1 and Timer2 counting */
- TIMER_Close(TIMER0);
- TIMER_Close(TIMER1);
- TIMER_Close(TIMER2);
- printf("*** PASS ***\n");
- while(1);
- /*** (C) COPYRIGHT 2014~2015 Nuvoton Technology Corp. ***/
