efm32 硬件SPI
2889|4
 楼主| 081616 发表于 2011-11-21 17:05 | 显示全部楼层 |阅读模式
void SPI_setup(uint8_t spiNumber, uint8_t location, bool master)
  USART_TypeDef *spi;
  /* Determining USART */
  switch (spiNumber)
  case 0:
    spi = USART0;
    break;
  case 1:
    spi = USART1;
    break;
  case 2:
   // spi = USART2;
    break;
  default:
    return;
    //USART_Reset(spi);
  /* Setting baudrate */
  spi->CLKDIV = 128 * (SPI_PERCLK_FREQUENCY / SPI_BAUDRATE - 2);
  /* Configure SPI */
  /* Using synchronous (SPI) mode*/
  //spi->CTRL = USART_CTRL_SYNC;//|USART_CTRL_CLKPHA;
   spi->CTRL = USART_CTRL_SYNC ;//|USART_CTRL_CLKPHA;//|USART_CTRL_CLKPOL ;
  //spi->FRAME|=USART_FRAME_DATABITS_EIGHT;
  /* Clearing old transfers/receptions, and disabling interrupts */
  spi->CMD = USART_CMD_CLEARRX | USART_CMD_CLEARTX;
  spi->IEN = 0;
  /* Enabling pins and setting location */
  spi->ROUTE = USART_ROUTE_TXPEN | USART_ROUTE_RXPEN | USART_ROUTE_CLKPEN | USART_ROUTE_CSPEN | (location << 8);
  /* Set GPIO config to slave */
  /* Set to master and to control the CS line */
  if (master)
    /* Enabling Master, TX and RX */
    spi->CMD   = USART_CMD_MASTEREN | USART_CMD_TXEN | USART_CMD_RXEN;
    spi->CTRL |= USART_CTRL_AUTOCS;
      /* 数据传输高位在前 */
     spi->CTRL |=USART_CTRL_MSBF;
    /* Set GPIO config to master */
    gpioModeMosi = gpioModePushPull;
    gpioModeMiso = gpioModePushPull;
    gpioModeCs   = gpioModePushPull;
    gpioModeClk  = gpioModePushPull;
  else
    /* Enabling TX and RX */
    spi->CMD = USART_CMD_TXEN | USART_CMD_RXEN;
    gpioModeMosi = gpioModeInput;
    gpioModeCs   = gpioModeInput;
    gpioModeClk  = gpioModeInput;
  /* Clear previous interrupts */
  spi->IFC = _USART_IFC_MASK;
  /* IO configuration */
  switch(spiNumber)
    case 0: switch(location)
              case 0: /* IO configuration (USART 0, Location #0) */
                      GPIO_PinModeSet(gpioPortE, 10, gpioModeMosi, 0); /* MOSI */
                      GPIO_PinModeSet(gpioPortE, 11, gpioModeMiso, 0); /* MISO */
                      GPIO_PinModeSet(gpioPortE, 13, gpioModeCs,   0); /* CS */
                      GPIO_PinModeSet(gpioPortE, 12, gpioModeClk,  0); /* Clock */
                      break;
              case 1: /* IO configuration (USART 0, Location #1) */
                      GPIO_PinModeSet(gpioPortE, 7, gpioModeMosi, 0);  /* MOSI */
                      GPIO_PinModeSet(gpioPortE, 6, gpioModeMiso, 0);  /* MISO */
                      GPIO_PinModeSet(gpioPortE, 4, gpioModeCs,   0);  /* CS */
                      GPIO_PinModeSet(gpioPortE, 5, gpioModeClk,  0);  /* Clock */
                      break;
              case 2: /* IO configuration (USART 0, Location #2) */
                      GPIO_PinModeSet(gpioPortC, 11, gpioModeMosi, 0); /* MOSI */
                      GPIO_PinModeSet(gpioPortC, 10, gpioModeMiso, 0); /* MISO */
                      GPIO_PinModeSet(gpioPortC,  8, gpioModeCs,   0); /* CS */
                      GPIO_PinModeSet(gpioPortC,  9, gpioModeClk,  0); /* Clock */
                      break;
            default: break;
            break;
    case 1: switch(location)
              case 0: /* IO configuration (USART 1, Location #0) */
                      GPIO_PinModeSet(gpioPortC, 0, gpioModeMosi, 0);  /* MOSI */
                      GPIO_PinModeSet(gpioPortC, 1, gpioModeMiso, 0);  /* MISO */
                      GPIO_PinModeSet(gpioPortB, 8, gpioModeCs,   0);  /* CS */
                      GPIO_PinModeSet(gpioPortB, 7, gpioModeClk,  0);  /* Clock */
                      break;
              case 1: /* IO configuration (USART 1, Location #1) */
                      GPIO_PinModeSet(gpioPortD, 0, gpioModeMosi, 0);  /* MOSI */
                      GPIO_PinModeSet(gpioPortD, 1, gpioModeMiso, 0);  /* MISO */
                      GPIO_PinModeSet(gpioPortD, 3, gpioModeCs,   0);  /* CS */
                      GPIO_PinModeSet(gpioPortD, 2, gpioModeClk,  0);  /* Clock */
                      break;
            default: break;
            break;
    case 2: switch(location)
              case 0: /* IO configuration (USART 2, Location #0) */
                      GPIO_PinModeSet(gpioPortC, 2, gpioModeMosi, 0);  /* MOSI */
                      GPIO_PinModeSet(gpioPortC, 3, gpioModeMiso, 0);  /* MISO */
                      GPIO_PinModeSet(gpioPortC, 5, gpioModeCs,   0);  /* CS */
                      GPIO_PinModeSet(gpioPortC, 4, gpioModeClk,  0);  /* Clock */
                      break;
              case 1: /* IO configuration (USART 2, Location #1) */
                      GPIO_PinModeSet(gpioPortB, 3, gpioModeMosi, 0);  /* MOSI */
                      GPIO_PinModeSet(gpioPortB, 4, gpioModeMiso, 0);  /* MISO */
                      GPIO_PinModeSet(gpioPortB, 6, gpioModeCs,   0);  /* CS */
                      GPIO_PinModeSet(gpioPortB, 5, gpioModeClk,  0);  /* Clock */
                      break;
            default: break;
            break;
    default: break;
我这里对其初始化,可是在示波器看到cs输出波形不对,请大家帮忙解决一下
 楼主| 081616 发表于 2011-11-22 09:21 | 显示全部楼层
自己顶一下,现在是读数据这出问题了,有某位大虾能给出读数据的程序么
 楼主| 081616 发表于 2011-11-22 09:22 | 显示全部楼层
1# 081616
mcuzonemcu3 发表于 2012-3-24 18:55 | 显示全部楼层
