STM32 VL DISCOVERY 探索套件的问题
7784|10
 楼主| 程序匠人 发表于 2011-11-22 00:09 | 显示全部楼层 |阅读模式
下面的红字问题,搞得有点头大。上网查了一通,看得云里雾里。好像是说芯片被锁了?请问该如何解决?
编译软件:IAR 6.20
_____________________________
Tue Nov 22, 2011 00:16:40: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 6.0\arm\config\flashloader\ST\FlashSTM32F10xxx.mac
Tue Nov 22, 2011 00:16:40: -I- execUserFlashInit!
Tue Nov 22, 2011 00:16:41: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 6.0\arm\config\flashloader\ST\FlashSTM32F10xxxRAM6K.out
Tue Nov 22, 2011 00:16:41: Target reset
Tue Nov 22, 2011 00:16:42: Downloaded J:\测试 探索套件an3268\stm32vldiscovery_package\Project\Demo\EWARMv5\DISCOVER\Exe\DISCOVER.out to flash memory.
Tue Nov 22, 2011 00:16:42: 2304 bytes downloaded into FLASH and verified (1.53 Kbytes/sec)
Tue Nov 22, 2011 00:16:42: Warning:
Verify error at address 0x08000000, target byte: 0x00, byte in file: 0x38
Verify error at address 0x08000004, target byte: 0xF9, byte in file: 0xFD
Verify error at address 0x08000005, target byte: 0x0B, byte in file: 0x07
Verify error at address 0x08000008, target byte: 0x59, byte in file: 0xE9
Verify error at address 0x08000009, target byte: 0x0A, byte in file: 0x07
Verify error at address 0x0800000C, target byte: 0x5B, byte in file: 0xEB
Verify error at address 0x0800000D, target byte: 0x0A, byte in file: 0x07
Verify error at address 0x08000010, target byte: 0x5D, byte in file: 0xED
Verify error at address 0x08000011, target byte: 0x0A, byte in file: 0x07
Verify error at address 0x08000014, target byte: 0x5F, byte in file: 0xEF
Verify error at address 0x08000015, target byte: 0x0A, byte in file: 0x07
Verify error at address 0x08000018, target byte: 0x61, byte in file: 0xF1
Verify error at address 0x08000019, target byte: 0x0A, byte in file: 0x07
Verify error at address 0x0800002C, target byte: 0x63, byte in file: 0xF3
Verify error at address 0x0800002D, target byte: 0x0A, byte in file: 0x07
Verify error at address 0x08000030, target byte: 0x65, byte in file: 0xF5
Verify error at address 0x08000031, target byte: 0x0A, byte in file: 0x07
Verify error at address 0x08000038, target byte: 0x67, byte in file: 0xF7
Verify error at address 0x08000039, target byte: 0x0A, byte in file: 0x07
Verify error at address 0x0800003C, target byte: 0x69, byte in file: 0xF9
Verify error at address 0x0800003D, target byte: 0x0A, byte in file: 0x07
Verify error at address 0x08000040, target byte: 0x79, byte in file: 0x3D
Verify error at address 0x08000041, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000044, target byte: 0x7B, byte in file: 0x41
Verify error at address 0x08000045, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000048, target byte: 0x7D, byte in file: 0x45
Verify error at address 0x08000049, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x0800004C, target byte: 0x7F, byte in file: 0x49
Verify error at address 0x0800004D, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000050, target byte: 0x81, byte in file: 0x4D
Verify error at address 0x08000051, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000054, target byte: 0x83, byte in file: 0x51
Verify error at address 0x08000055, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000058, target byte: 0x85, byte in file: 0x55
Verify error at address 0x08000059, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x0800005C, target byte: 0x87, byte in file: 0x59
Verify error at address 0x0800005D, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000060, target byte: 0x89, byte in file: 0x5D
Verify error at address 0x08000061, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000064, target byte: 0x8B, byte in file: 0x61
Verify error at address 0x08000065, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000068, target byte: 0x8D, byte in file: 0x65
Verify error at address 0x08000069, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x0800006C, target byte: 0x8F, byte in file: 0x69
Verify error at address 0x0800006D, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000070, target byte: 0x91, byte in file: 0x6D
Verify error at address 0x08000071, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000074, target byte: 0x93, byte in file: 0x71
Verify error at address 0x08000075, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000078, target byte: 0x95, byte in file: 0x75
Verify error at address 0x08000079, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x0800007C, target byte: 0x97, byte in file: 0x79
Verify error at address 0x0800007D, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000080, target byte: 0x99, byte in file: 0x7D
Verify error at address 0x08000081, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000084, target byte: 0x9B, byte in file: 0x81
Verify error at address 0x08000085, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x08000088, target byte: 0x9D, byte in file: 0x85
Verify error at address 0x08000089, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x0800009C, target byte: 0x9F, byte in file: 0x89
Verify error at address 0x0800009D, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000A0, target byte: 0xA1, byte in file: 0x8D
Verify error at address 0x080000A1, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000A4, target byte: 0xA3, byte in file: 0x91
Verify error at address 0x080000A5, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000A8, target byte: 0xA5, byte in file: 0x95
Verify error at address 0x080000A9, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000AC, target byte: 0xA7, byte in file: 0x99
Verify error at address 0x080000AD, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000B0, target byte: 0xA9, byte in file: 0x9D
Verify error at address 0x080000B1, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000B4, target byte: 0xAB, byte in file: 0xA1
Verify error at address 0x080000B5, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000B8, target byte: 0xAD, byte in file: 0xA5
Verify error at address 0x080000B9, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000BC, target byte: 0xAF, byte in file: 0xA9
Verify error at address 0x080000BD, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000C0, target byte: 0xB1, byte in file: 0xAD
Verify error at address 0x080000C1, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000C4, target byte: 0xB3, byte in file: 0xB1
Verify error at address 0x080000C5, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000C9, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000CC, target byte: 0xB7, byte in file: 0xB9
Verify error at address 0x080000CD, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000D0, target byte: 0xB9, byte in file: 0xBD
Verify error at address 0x080000D1, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000D4, target byte: 0xBB, byte in file: 0xC1
Verify error at address 0x080000D5, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000D8, target byte: 0xBD, byte in file: 0xC5
Verify error at address 0x080000D9, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000DC, target byte: 0xBF, byte in file: 0xC9
Verify error at address 0x080000DD, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000E0, target byte: 0xC1, byte in file: 0xCD
Verify error at address 0x080000E1, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000E4, target byte: 0xC3, byte in file: 0xD1
Verify error at address 0x080000E5, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000E8, target byte: 0xC5, byte in file: 0xD5
Verify error at address 0x080000E9, target byte: 0x0A, byte in file: 0x08
Verify error at address 0x080000EC, target byte: 0xC7, byte in file: 0x00
Verify error at address 0x080000ED, target byte: 0x0A, byte in file: 0x00
Verify error at address 0x080000EF, target byte: 0x08, byte in file: 0x00
Verify error at address 0x080000F0, target byte: 0xC9, byte in file: 0x00
Verify error at address 0x080000F1, target byte: 0x0A, byte in file: 0x00
Verify error at address 0x080000F3, target byte: 0x08, byte in file: 0x00
Verify error at address 0x080000F4, target byte: 0x40, byte in file: 0x00
Verify error at address 0x080000F5, target byte: 0xB2, byte in file: 0x00
Verify error at address 0x080000F7, target byte: 0x28, byte in file: 0x00
Verify error at address 0x080000F8, target byte: 0x09, byte in file: 0x00
Verify error at address 0x080000F9, target byte: 0xD5, byte in file: 0x00
Verify error at address 0x080000FA, target byte: 0x40, byte in file: 0x00
Verify error at address 0x080000FB, target byte: 0xB2, byte in file: 0x00
Verify error at address 0x080000FC, target byte: 0x10, byte in file: 0x00
Verify error at address 0x080000FD, target byte: 0xF0, byte in file: 0x00
Verify error at address 0x080000FE, target byte: 0x0F, byte in file: 0x00
Verify error at address 0x08000100, target byte: 0xDF, byte in file: 0x00
Verify error at address 0x08000101, target byte: 0xF8, byte in file: 0x00
Verify error at address 0x08000102, target byte: 0xAC, byte in file: 0x00
Verify error at address 0x08000103, target byte: 0x25, byte in file: 0x00
Verify error at address 0x08000104, target byte: 0x80, byte in file: 0x00
Verify error at address 0x08000105, target byte: 0x18, byte in file: 0x00
Verify error at address 0x08000106, target byte: 0x09, byte in file: 0x00
Verify error at address 0x08000107, target byte: 0x01, byte in file: 0x00
Verify error at address 0x08000109, target byte: 0xF8, byte in file: 0x00
Verify error at address 0x0800010A, target byte: 0x04, byte in file: 0x00
Verify error at address 0x0800010B, target byte: 0x1C, byte in file: 0x00
Verify error at address 0x0800010C, target byte: 0x04, byte in file: 0x00
Verify error at address 0x0800010D, target byte: 0xE0, byte in file: 0x00
Verify error at address 0x0800010E, target byte: 0x40, byte in file: 0x00
Verify error at address 0x0800010F, target byte: 0xB2, byte in file: 0x00
Verify error at address 0x08000110, target byte: 0xDF, byte in file: 0x00
Verify error at address 0x08000111, target byte: 0xF8, byte in file: 0x00
Verify error at address 0x08000112, target byte: 0xA0, byte in file: 0x00
Verify error at address 0x08000113, target byte: 0x25, byte in file: 0x00
Verify error at address 0x08000114, target byte: 0x09, byte in file: 0x00
Verify error at address 0x08000115, target byte: 0x01, byte in file: 0x00
Verify error at address 0x08000116, target byte: 0x81, byte in file: 0x00
Verify error at address 0x08000117, target byte: 0x54, byte in file: 0x00
Verify error at address 0x08000118, target byte: 0x70, byte in file: 0xD9
Verify error at address 0x08000119, target byte: 0x47, byte in file: 0x08
Verify error at address 0x0800011A, target byte: 0x80, byte in file: 0x00
Verify error at address 0x0800011B, target byte: 0xB5, byte in file: 0x08
Verify error at address 0x0800011C, target byte: 0xB0, byte in file: 0xDD
Verify error at address 0x0800011D, target byte: 0xF1, byte in file: 0x08
Verify error at address 0x0800011E, target byte: 0x80, byte in file: 0x00
Verify error at address 0x0800011F, target byte: 0x7F, byte in file: 0x08
Verify error at address 0x08000120, target byte: 0x01, byte in file: 0x38
Verify error at address 0x08000121, target byte: 0xD3, byte in file: 0xB5
Verify error at address 0x08000123, target byte: 0x20, byte in file: 0x21
Verify error at address 0x08000124, target byte: 0x13, byte in file: 0x4F
Verify error at address 0x08000125, target byte: 0xE0, byte in file: 0xF0
Verify error at address 0x08000126, target byte: 0x00, byte in file: 0x80
Verify error at address 0x08000127, target byte: 0x02, byte in file: 0x50
Verify error at address 0x08000129, target byte: 0x0A, byte in file: 0xF0
Verify error at address 0x0800012A, target byte: 0x40, byte in file: 0xE0
Verify error at address 0x0800012B, target byte: 0x1E, byte in file: 0xF8
Verify error at address 0x0800012C, target byte: 0xDF, byte in file: 0x00
Verify error at address 0x0800012D, target byte: 0xF8, byte in file: 0x20
Verify error at address 0x0800012E, target byte: 0x88, byte in file: 0x00
Verify error at address 0x0800012F, target byte: 0x15, byte in file: 0xF0
Verify error at address 0x08000130, target byte: 0x08, byte in file: 0x03
Verify error at address 0x08000131, target byte: 0x60, byte in file: 0xF9
Verify error at address 0x08000132, target byte: 0x0F, byte in file: 0x01
Verify error at address 0x08000133, target byte: 0x21, byte in file: 0x20
Verify error at address 0x08000134, target byte: 0x5F, byte in file: 0x00
Verify error at address 0x08000136, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x08000137, target byte: 0x30, byte in file: 0xF9
Verify error at address 0x08000138, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x08000139, target byte: 0xF7, byte in file: 0x20
Verify error at address 0x0800013A, target byte: 0xDC, byte in file: 0x00
Verify error at address 0x0800013B, target byte: 0xFF, byte in file: 0xF0
Verify error at address 0x0800013C, target byte: 0xDF, byte in file: 0x23
Verify error at address 0x0800013D, target byte: 0xF8, byte in file: 0xF9
Verify error at address 0x0800013E, target byte: 0x7C, byte in file: 0x00
Verify error at address 0x0800013F, target byte: 0x05, byte in file: 0xF0
Verify error at address 0x08000140, target byte: 0x00, byte in file: 0xA7
Verify error at address 0x08000141, target byte: 0x21, byte in file: 0xF8
Verify error at address 0x08000142, target byte: 0x01, byte in file: 0x00
Verify error at address 0x08000143, target byte: 0x60, byte in file: 0x21
Verify error at address 0x08000144, target byte: 0xDF, byte in file: 0x00
Verify error at address 0x08000145, target byte: 0xF8, byte in file: 0x20
Verify error at address 0x08000146, target byte: 0x78, byte in file: 0x00
Verify error at address 0x08000147, target byte: 0x05, byte in file: 0xF0
Verify error at address 0x08000148, target byte: 0x07, byte in file: 0x26
Verify error at address 0x08000149, target byte: 0x21, byte in file: 0xF9
Verify error at address 0x0800014A, target byte: 0x01, byte in file: 0x59
Verify error at address 0x0800014B, target byte: 0x60, byte in file: 0x48
Verify error at address 0x0800014D, target byte: 0x20, byte in file: 0x68
Verify error at address 0x0800014E, target byte: 0x02, byte in file: 0x4F
Verify error at address 0x0800014F, target byte: 0xBD, byte in file: 0xF4
Verify error at address 0x08000150, target byte: 0x80, byte in file: 0x7A
Verify error at address 0x08000151, target byte: 0xB5, byte in file: 0x71
Verify error at address 0x08000152, target byte: 0x01, byte in file: 0xB0
Verify error at address 0x08000153, target byte: 0x21, byte in file: 0xFB
Verify error at address 0x08000154, target byte: 0x10, byte in file: 0xF1
Verify error at address 0x08000155, target byte: 0x20, byte in file: 0xF0
Verify error at address 0x08000156, target byte: 0x00, byte in file: 0xB0
Verify error at address 0x08000157, target byte: 0xF0, byte in file: 0xF1
Verify error at address 0x08000158, target byte: 0x73, byte in file: 0x80
Verify error at address 0x08000159, target byte: 0xFB, byte in file: 0x7F
Verify error at address 0x0800015A, target byte: 0xDF, byte in file: 0x2C
Verify error at address 0x0800015B, target byte: 0xF8, byte in file: 0xD2
Tue Nov 22, 2011 00:16:42: Warning: Too many verify errors, only the first 200 are displayed
Tue Nov 22, 2011 00:16:43: Warning: There were warnings during download, see Log Window
Tue Nov 22, 2011 00:16:43: Loaded debugee: J:\测试 探索套件an3268\stm32vldiscovery_package\Project\Demo\EWARMv5\DISCOVER\Exe\DISCOVER.out
Tue Nov 22, 2011 00:16:44: Target reset
Tue Nov 22, 2011 00:16:44: There was 1 warning during the initialization of the debugging session.
airwill 发表于 2011-11-22 08:45 | 显示全部楼层
呵呵, 匠人也犯糊涂?
好象程序没有擦除哦, 是不是下载的设置问题.
 楼主| 程序匠人 发表于 2011-11-22 09:04 | 显示全部楼层
呵呵, 匠人也犯糊涂?
好像是被保护了。
IJK 发表于 2011-11-22 10:44 | 显示全部楼层
好像是被保护了。
被保护是指被读、写保护吗?
读、写保护很容易解决,JLINK有个小工具可以去除,还可以用STM32 VL DISCOVERY 上面的STLINK/V2通过STVP软件去除读、写保护。
 楼主| 程序匠人 发表于 2011-11-22 13:05 | 显示全部楼层
下载了一个STVP,把芯片擦除了。但是现在编译又出新问题:
Tue Nov 22, 2011 13:21:46: User error: Stack pointer is setup to incorrect alignment.  Stack addr = 0xFFFFFFFF
lut1lut 发表于 2011-11-22 17:32 | 显示全部楼层
网上搜到的。
http://supp.iar.com/Support/?note=82023&from=search+result
另外,STVP解除保护后板子要断电哦。
airwill 发表于 2011-11-23 08:27 | 显示全部楼层
Stack addr = 0xFFFFFFFF 感觉这是启动文件的问题
因为 STACK pointer 在中断向量表头上, 是 ROM 入口
IJK 发表于 2011-11-23 09:17 | 显示全部楼层
感觉是开发环境和硬件还没有匹配上。
记得STM32 VL DISCOVERY 有官方的例程、Demo,建议用相应的例程、Demo先试试
 楼主| 程序匠人 发表于 2011-11-23 12:42 | 显示全部楼层
谢谢楼上3位。
经过进一步的摸索和请教。
发现目前,用STVP可以正常读写芯片。这证明板子没问题,芯片也没问题。
那么可能是IAR版本的问题,尚待进一步验证。
 楼主| 程序匠人 发表于 2011-11-23 17:51 | 显示全部楼层
l结果汇报:
把IAR6.2卸载,改用IAR6.1,可以正常下载仿真了。
感谢楼上各位的帮助,其中,IJK 提供的关于STVP的信息对我最有价值。因此决定把大部分悬赏分送给你。
另要感谢ST的梁工和唐工,以及国家、政府、党和人民。:P
秋天落叶 发表于 2011-11-23 18:19 | 显示全部楼层
匠人解决问题就是快
个人签名: 《匠人手记》第二版已经上市,各大网络书店和实体书店有售! 匠人手机——手机中的颤抖机!欧耶! 匠人手记——手记中的战斗记!欧耶!
734
