[芯事漫谈] 定制型AES256加密芯片IDKT 封装电路图 特性
756|0
 楼主| Globalizex 发表于 2019-10-25 14:18 | 显示全部楼层 |阅读模式
file:///C:\Users\GLOBAL~1\AppData\Local\Temp\ksohtml3300\wps1.pngGeneral Description
The IDKT is a family of high performance AES256 CODEC with cipher memory device providing 2K Bytes of user memory.
Features
l A illegal Copy Protection IC
l Random Stream Cipher for Interface
l 2K Bytes Secure EEPROM
l I2C or 1-Wire Communication Protocol Support 40-bit Unique serial number
l Support MTP/OTP User Area
l Only Increment Counting Function
  for Inkjet Printer and Cartridge
l Input Voltage Range 1.8V ~ 3.6V
l Power On/Off for Low Power Mode
l Available Package SOT23/8SOP/TDFN
Benefits
l Protection illegal reproduction
l Mass production control
l Receiving royalty from SW/HW
Applications
l Authorization using Cipher EEPROM
l Contents Encryption and Decryption
l Network Authorization
l Anti-clone protection
l Secure boot
l Printer cartridge, Water purifier
l All of Electronic Systems Using
  MCU/ CPU / AP
个人签名:全球芯科技(MCU/Memory/5G模组/安全加密芯片) 13924645577(微信同号)
61
