[DemoCode下载] M451点灯
572|11
 楼主| xixi2017 发表于 2019-10-31 20:38 | 显示全部楼层 |阅读模式
ck, TE, se, rc
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * $Date: 15/09/02 10:03a $
  5. * [url=home.php?mod=space&uid=247401]@brief[/url]    Toggle PC.9 to turn on / off the board LED
  6. *
  7. * @note
  8. * Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
  9. *
  10. ******************************************************************************/
  11. #include <stdio.h>
  12. #include "M451Series.h"
  13. #define HCLK_CLOCK       72000000
  14. void SYS_Init(void)
  15. {
  16.     /*---------------------------------------------------------------------------------------------------------*/
  17.     /* Init System Clock        */
  18.     /*---------------------------------------------------------------------------------------------------------*/
  19.     /* Unlock protected registers */
  20.     SYS_UnlockReg();
  21.     /* Enable HIRC clock (Internal RC 22.1184MHz) */
  22.     CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
  23.     /* Wait for HIRC clock ready */
  24.     CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
  25.     /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
  26.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
  27.     /* Enable HXT clock (external XTAL 12MHz) */
  28.     CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
  29.     /* Wait for HXT clock ready */
  30.     CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
  31.     /* Set core clock as HCLK_CLOCK */
  32.     CLK_SetCoreClock(HCLK_CLOCK);
  33.     /* Update System Core Clock */
  34.     /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
  35.     SystemCoreClockUpdate();
  36.     /*---------------------------------------------------------------------------------------------------------*/
  37.     /* Init I/O Multi-function        */
  38.     /*---------------------------------------------------------------------------------------------------------*/
  39.     /* Set GPD multi-function pins for UART0 RXD and TXD */
  40.     SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
  41.     SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
  42.     /* Lock protected registers */
  43.     SYS_LockReg();
  44. }
  45. /*---------------------------------------------------------------------------------------------------------*/
  46. /* MAIN function        */
  47. /*---------------------------------------------------------------------------------------------------------*/
  48. int main(void)
  49. {
  50.     /* Init System, IP clock and multi-function I/O
  51.        In the end of SYS_Init() will issue SYS_LockReg()
  52.        to lock protected register. If user want to write
  53.        protected register, please issue SYS_UnlockReg()
  54.        to unlock protected register if necessary */
  55.     SYS_Init();
  56.     /* Select SysTick clock source as HXT */
  57.     CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HXT);
  58.     /* Configure PC.9 as Output mode */
  59.     GPIO_SetMode(PC, BIT9, GPIO_MODE_OUTPUT);
  60.     while(1)
  61.     {
  62.         /* Configure PC.9 to low */
  63.         PC9 = 0;
  64.         /* Delay 200 ms */
  65.         CLK_SysTickDelay(200000);
  66.         /* Configure PC.9 to high */
  67.         PC9 = 1;
  68.         /* Delay 200 ms */
  69.         CLK_SysTickDelay(200000);
  70.     }
  71. }
 楼主| xixi2017 发表于 2019-10-31 20:39 | 显示全部楼层
72M的时钟非常给力。这个芯片真不错。
提供了高精度的延时函数,直接可以用于各种时序操作。
 楼主| xixi2017 发表于 2019-10-31 20:40 | 显示全部楼层
     PC9 = 0;
这种操作一般在51中才有的,库函数给通过宏实现了,方便编程。
gaoyang9992006 发表于 2019-10-31 21:02 | 显示全部楼层
例子虽然简单,但是包含了,时钟的选择和配置,端口的选择和配置,以及端口初始化,调用库函数等操作。
598330983 发表于 2019-11-4 23:13 | 显示全部楼层
点灯后就好办了。
天灵灵地灵灵 发表于 2019-11-7 00:10 | 显示全部楼层
不知道新唐什么时候出个全面的图形化配置工具
yiyigirl2014 发表于 2019-11-7 19:01 | 显示全部楼层
好久没玩过板子了。
dongliushui 发表于 2019-11-7 22:11 | 显示全部楼层
可以实现类似51单片机的IO操作。
小灵通2018 发表于 2019-11-7 23:29 | 显示全部楼层
操作确实简单,容易理解。
小明的同学 发表于 2019-11-9 10:53 | 显示全部楼层
RC精度如何
可以用于时钟吗
