上次的分享,我们获取了一枚天气信息,但是呢,信息最重要的属性之一就是时效性,如何去确认我们信息的时效性呢,简单,保持自己时间的准确喽。 Time is valuable thing! 时间对我们是很重要的。通常,我们需要进行时间校准(PS:在很多时候,你细心留意就发现时间是错误的),一般就可以用NTP服务器进行获取时间信息,下面使用零知-ESP8266上进行NTP时间的获取。 一、硬件
电脑,windows系统
零知ESP8266开发板
micro-usb线
二、
(1)打开零知开源开发软件,选择零知ESP8266开发板,界面如图所示: (2)电脑连接零知ESP8266开发板 (3)烧写程序:
①可以直接选择软件中的示例程序
②也可以上传以下代码: - /*
- * TimeNTP_ESP8266WiFi.ino
- * Example showing time sync to NTP time source
- * This sketch uses the ESP8266WiFi library
- #include <TimeLib.h>
- #include <ESP8266WiFi.h>
- #include <WiFiUdp.h>
- const char ssid[] = "xx"; // your network SSID (name)
- const char pass[] = "xx"; // your network password
- // NTP Servers:
- static const char ntpServerName[] = "cn.ntp.org.cn";
- //static const char ntpServerName[] = "time.nist.gov";
- //static const char ntpServerName[] = "time-a.timefreq.bldrdoc.gov";
- //static const char ntpServerName[] = "time-b.timefreq.bldrdoc.gov";
- //static const char ntpServerName[] = "time-c.timefreq.bldrdoc.gov";
- const int timeZone = 8; //BeiJing in China
- // const int timeZone = 1; // Central European Time
- //const int timeZone = -5; // Eastern Standard Time (USA)
- //const int timeZone = -4; // Eastern Daylight Time (USA)
- //const int timeZone = -8; // Pacific Standard Time (USA)
- //const int timeZone = -7; // Pacific Daylight Time (USA)
- WiFiUDP Udp;
- unsigned int localPort = 8888; // local port to listen for UDP packets
- time_t getNtpTime();
- void digitalClockDisplay();
- void printDigits(int digits);
- void sendNTPpacket(IPAddress &address);
- void setup()
- Serial.begin(9600);
- while (!Serial) ; // Needed for Leonardo only
- delay(250);
- Serial.println("TimeNTP Example");
- Serial.print("Connecting to ");
- Serial.println(ssid);
- WiFi.begin(ssid, pass);
- while (WiFi.status() != WL_CONNECTED) {
- delay(500);
- Serial.print(".");
- Serial.print("IP number assigned by DHCP is ");
- Serial.println(WiFi.localIP());
- Serial.println("Starting UDP");
- Udp.begin(localPort);
- Serial.print("Local port: ");
- Serial.println(Udp.localPort());
- Serial.println("waiting for sync");
- setSyncProvider(getNtpTime);
- setSyncInterval(300);
- time_t prevDisplay = 0; // when the digital clock was displayed
- void loop()
- if (timeStatus() != timeNotSet) {
- if (now() != prevDisplay) { //update the display only if time has changed
- prevDisplay = now();
- digitalClockDisplay();
- // digital clock display of the time
- Serial.print(hour());
- printDigits(minute());
- printDigits(second());
- Serial.print(" ");
- Serial.print(day());
- Serial.print(month());
- Serial.print(year());
- Serial.println();
- // utility for digital clock display: prints preceding colon and leading 0
- Serial.print(":");
- if (digits < 10)
- Serial.print('0');
- Serial.print(digits);
- /*-------- NTP code ----------*/
- const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
- byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
- IPAddress ntpServerIP; // NTP server's ip address
- while (Udp.parsePacket() > 0) ; // discard any previously received packets
- Serial.println("Transmit NTP Request");
- // get a random server from the pool
- WiFi.hostByName(ntpServerName, ntpServerIP);
- Serial.print(ntpServerName);
- Serial.print(": ");
- Serial.println(ntpServerIP);
- sendNTPpacket(ntpServerIP);
- uint32_t beginWait = millis();
- while (millis() - beginWait < 1500) {
- int size = Udp.parsePacket();
- if (size >= NTP_PACKET_SIZE) {
- Serial.println("Receive NTP Response");
- Udp.read(packetBuffer, NTP_PACKET_SIZE); // read packet into the buffer
- unsigned long secsSince1900;
- // convert four bytes starting at location 40 to a long integer
- secsSince1900 = (unsigned long)packetBuffer[40] << 24;
- secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
- secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
- secsSince1900 |= (unsigned long)packetBuffer[43];
- return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
- Serial.println("No NTP Response :-(");
- return 0; // return 0 if unable to get the time
- // send an NTP request to the time server at the given address
- // set all bytes in the buffer to 0
- memset(packetBuffer, 0, NTP_PACKET_SIZE);
- // Initialize values needed to form NTP request
- // (see URL above for details on the packets)
- packetBuffer[0] = 0b11100011; // LI, Version, Mode
- packetBuffer[1] = 0; // Stratum, or type of clock
- packetBuffer[2] = 6; // Polling Interval
- packetBuffer[3] = 0xEC; // Peer Clock Precision
- // 8 bytes of zero for Root Delay & Root Dispersion
- packetBuffer[12] = 49;
- packetBuffer[13] = 0x4E;
- packetBuffer[14] = 49;
- packetBuffer[15] = 52;
- // all NTP fields have been given values, now
- // you can send a packet requesting a timestamp:
- Udp.beginPacket(address, 123); //NTP requests are to port 123
- Udp.write(packetBuffer, NTP_PACKET_SIZE);
- Udp.endPacket();
然后验证,并且上传到开发板。 四、结果 然后对照自己的时间: 赶紧动手检查看看自己的时间对不对呢?
我先校准自己的。 顺便问你们一句:有没有发现自己的时间变快了呢?(细思极恐)
