[DSP] 编译通不过,麻烦大佬们看一下
541|2
 楼主| 在路上111 发表于 2019-11-18 16:32 | 显示全部楼层 |阅读模式
<Linking>
undefined first referenced
  symbol       in file
_main     F:\ti\ccsv5\tools\compiler\c2000_6.1.0\lib\rts2800_ml.lib<args_main.obj>
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "SPWM_single.out" not built
>> Compilation failure
gmake: *** [SPWM_single.out] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
Description        Resource        Path        Location        Type
unresolved symbol _main, first referenced in F:\ti\ccsv5\tools\compiler\c2000_6.1.0\lib\rts2800_ml.lib<args_main.obj>        SPWM_single                         C/C++ Problem
zhangmangui 发表于 2019-11-18 21:32 | 显示全部楼层
缺少什么文件吧
或者有未定义的变量等吧
