新人求助,有关cc2530的
795|1
 楼主| yzywuyou 发表于 2019-11-25 14:45 | 显示全部楼层 |阅读模式
代码是这样的,但实现不了SW1的按键1的功能,我中断实现不了
#include"iocc2530.h"
#define D3 P1_0
#define D4 P1_1
#define SW1 P1_2
#define D5 P1_3
#define D6 P1_4
#define SW2 P0_1
unsigned char count=0;
unsigned char k_num=0;
unsigned char Count=0;
unsigned char K_num=0;
int i;
void delay(int t){
    for(int i=0;i<t;i++){
        for(int j=0;j<240;j++);
void init_LED(){
    for(i=0;i<2;i++){
        P1SEL &=~0x1b;
        P1DIR |=0x1b;
        D3=1;
        D4=1;
        D5=1;
        D6=1;
        delay(1000);
        D3=0;
        D4=0;
        D5=0;
        D6=0;
        delay(1000);
    D3=1;
    D4=1;
    D5=1;
    D6=1;
void Init_SW(){
    P1SEL &=~0X04;
    P1DIR &=~0X04;
    P0SEL &=~0x01;
    P0DIR &=~0x01;
void Init_T1(){
    EA=1;
    T1IE=1;
    T1CCTL0|=0X04;
    T1CC0L=0X30;
    T1CC0H=0XFA;
    T1CTL|=0X0e;
void Scan_Key(){
  if(SW1==0){
    delay(10);
    if(SW1==0){
      while(SW1==0);
      count=0;
      k_num++;
     if(k_num>3){
       k_num=3;
if(count >4){
   switch(k_num){
   case 2:
     D4=~D4;
     delay(10);
   break;
   case 3:
     D3=~D3;
     delay(10);
   break;
   k_num=0;
   count=0;
void Scan_key(){
    if(SW2==0){
        delay(10);
        if(SW2==0){
            while(!SW2);
                Count++;
                K_num++;
                if(K_num>3){
                    K_num=3;
        if(Count>4){
            switch(K_num){
                case 2:
                    D6=~D6;
                    delay(10);
                    break;
                case 3:
                    D5=~D5;
                    delay(10);
                    break;
        K_num=0;
        Count=0;
void IAR_Init(){
    IEN2 |= 0X10; //选择P1端口 使P1
    P1IEN |= 0X04;
    PICTL |= 0X02;
    EA = 1;//总中断
void main(){
    Init_T1();
    init_LED();
    Init_SW();
    Init_T1();
    while(1){
        Scan_Key();
        Scan_key();
#pragma vector=T1_VECTOR
__interrupt void T1_SIR(void){
    T1STAT &=~0x20;
    if(k_num !=0&&SW1 !=0){
        count++;
    if(K_num !=0&&SW2 !=0){
        Count++;
#pragma vector = P1INT_VECTOR
__interrupt void SW1_ISR(void){
  if(P1IF==1){
    if(P1IFG & 0X04){
              if(k_num==1){
                delay(500);
                if(k_num==1){
                D3=1;
                D4=1;
                D5=1;
                D6=1;
                delay(1000);
                D3=0;
                D4=0;
                D5=0;
                D6=0;
        count=0;
        k_num=0;
        P1IF = 0;
        P1IFG &= ~0X04;
 楼主| yzywuyou 发表于 2019-11-25 14:47 | 显示全部楼层
这个是要实现的功能
