[活动]
EFM8BB1测评---模拟I2C读取AT24C04
1885|3
今晚捣鼓了一下模拟I2C读取AT24C04。
代码:
// Includes
#include "SI_EFM8BB1_Register_Enums.h"                // SFR declarations
#include "InitDevice.h"
#define uchar unsigned char
#define uint unsigned int
// Pin Declarations
SI_SBIT(LED, SFR_P1, 4);   // LED
SI_SBIT(S1, SFR_P0, 2);                                   // BTN0
SI_SBIT(SCL, SFR_P1, 6);   // SCL
SI_SBIT(SDA, SFR_P0, 7);                                   // SDA
// Global Constants
#define SYSCLK      24500000/8         // Clock speed in Hz (default)
#define SW_PRESSED           0
#define SW_NOT_PRESSED       1
#define LED_ON               0
#define LED_OFF              1
//#define SCL_1                1
//#define SCL_0                                 0
//#define SDA_1                                1
//#define SDA_0                                0
unsigned char buffer[3];
void InitSCL(void)
        P1MDOUT = P1MDOUT_B6__OPEN_DRAIN ;
void InitSDAInput(void)
        //P1MDIN = P1MDIN_B6__BMASK | P1MDIN_B6__SHIFT | P1MDIN_B6__DIGITAL;
        //P1MDIN = P1MDIN_B7__DIGITAL ;
        //P1SKIP = P1SKIP_B7__SKIPPED ;
        P0SKIP =  P0SKIP_B7__SKIPPED;
void InitSDAOutput(void)
        P0MDOUT = P0MDOUT_B7__OPEN_DRAIN ;
void Delay(unsigned char us)  //5,7,9
  while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
void Start()
        InitSDAOutput();
        InitSCL();
        SCL=1;
        Delay(10);
        SDA=1;
        Delay(10);
        SDA=0;
        Delay(10);
        SCL=0;
        Delay(10);
void Stop()
        InitSDAOutput();
        InitSCL();
        SDA=0;
        Delay(10);
        SCL=1;
        Delay(10);
        SDA=1;
        Delay(10);
char ACK ()
        char c;
        InitSDAOutput();
        InitSCL();
        SDA=1;
        Delay(10);
        SCL=1;
        Delay(10);
        InitSDAInput();
        Delay(10);
        if(SDA)
                c=1;
        else
                c=0;
        Delay(10);
        InitSDAOutput();
        Delay(10);
        SCL=0;
        Delay(10);
        return c;
void SendChar(unsigned char ch)
  unsigned char i;
  i=8;
        InitSDAOutput();
        InitSCL();
  do
    if(ch&0x80)
      SDA=1;
    else
      SDA=0;
                Delay(10);
    SCL=1;
                Delay(10);
    SCL=0;
                Delay(10);
    ch<<=1;
  }while(--i!=0);
unsigned char RecChar()
  unsigned char i,j;
  i=8;
  j=0;
        InitSCL();
        InitSDAInput();
        Delay(10);
  do
    SCL=1;
                Delay(10);
    j=(j<<1);
    if(SDA)
      j=j|SDA;
                Delay(10);
    SCL=0;
                Delay(10);
  }while(--i!=0);
        InitSDAOutput();
  return j;
void WriteChar(unsigned int addr,unsigned char ch)
  unsigned char c;
  c=((*((unsigned char *)&addr))<<1)&0x02;
  Start();
  SendChar(0xa0|c);
  ACK();
  SendChar(addr);
  ACK();
  SendChar(ch);
  ACK();
  Stop();
  for(ch=0xff;ch!=0;ch--) ;
unsigned char ReadChar(unsigned int addr)
  unsigned char ch;
  ch=((*((unsigned char *)&addr))<<1)&0x02;
  Start();
  SendChar(0xa0|ch);
  ACK();
  SendChar(addr);
  ACK();
  Start();
  SendChar(0xa1|ch);
  ACK();
  ch=RecChar();
  Stop();
  return ch;
// SiLabs_Startup() Routine
// This function is called immediately after reset, before the initialization
// code is run in SILABS_STARTUP.A51 (which runs before main() ). This is a
// useful place to disable the watchdog timer, which is enable by default
// and may trigger before main() in some instances.
void SiLabs_Startup (void)
  // Disable the watchdog here
// main() Routine
// Note: the software watchdog timer is not disabled by default in this
// example, so a long-running program will reset periodically unless
// the timer is disabled or your program periodically writes to it.
// Review the "Watchdog Timer" section under the part family's datasheet
// for details. To find the datasheet, select your part in the
// Simplicity Launcher and click on "Data Sheet".
int main (void)
        unsigned int i;
        char flag=0;
        enter_DefaultMode_from_RESET();
        InitSCL();
        InitSDAOutput();
        buffer[0]=ReadChar(0);
        Delay(100);           //??????
        WriteChar(0,0x55);
        Delayms(20);
        WriteChar(1,0xaa);
        Delayms(20);
        WriteChar(2,0x25);
        Delayms(20);
        buffer[0]=ReadChar(1);
        buffer[1]=ReadChar(2);
        buffer[2]=ReadChar(0);
  while (1)
  }                             // Spin forever
效果图:
Yiqil| | 2022-3-18 09:40 | 只看该作者
InitSCL()和InitSDAOutput() 置为OPEN_DRAIN是为了拉高SCL和SDA吗?
suguibin02| | 2022-12-1 13:06 | 只看该作者
楼主,愿意接个项目吗?  也是EFM8单片机,联系VX: "GPS_CXWL"
Cjy_JDxy|  楼主 | 2023-1-12 23:50 | 只看该作者
接不了,没时间。
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
