[国产单片机]
【东软载波ESF0654 PDS开发板活动】+按键
629|1
Cjy_JDxy|  楼主 | 2019-12-15 19:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
今晚捣鼓了一下按键。
代码:
#define LED2_GPIO_PORT GPIOC
#define LED2_GPIO_PIN  MD_GPIO_PIN_9
#define KEY_GPIO_PORT GPIOF
#define KEY_GPIO_PIN  MD_GPIO_PIN_0
#include "main.h"
/** @addtogroup Projects_Examples_MD
/** @addtogroup Examples
#define uchar unsigned char
#define uint  unsigned int
  * @brief  This function configures GPIO
  * @param  None
  * @retval None
void config_gpio(void)
        md_gpio_set_pin_function(KEY_GPIO_PORT, KEY_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(KEY_GPIO_PORT, KEY_GPIO_PIN);
        md_gpio_set_pin_mode_input(KEY_GPIO_PORT, KEY_GPIO_PIN);
        md_gpio_set_pin_function(LED2_GPIO_PORT, LED2_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(LED2_GPIO_PORT, LED2_GPIO_PIN);
        md_gpio_set_pin_mode_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
  * @brief  Test main function
  * @retval Status.
int main()
        md_init_1ms_tick();
        config_gpio();
        while (1)
                if(md_gpio_get_input_data(KEY_GPIO_PORT, KEY_GPIO_PIN)==0)
                        md_gpio_set_pin_low(LED2_GPIO_PORT, LED2_GPIO_PIN);
                else
                        md_gpio_set_pin_high(LED2_GPIO_PORT, LED2_GPIO_PIN);
效果图:
一路向北lm| | 2019-12-15 21:19 | 只看该作者
你们好狡猾,都用 ST-Link
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
