[国产单片机] 【东软载波ESF0654 PDS开发板活动】+HT1621
871|0
 楼主| Cjy_JDxy 发表于 2019-12-15 20:17 | 显示全部楼层 |阅读模式
今晚捣鼓了一下HT1621
代码:
#include "main.h"
/** @addtogroup Projects_Examples_MD
/** @addtogroup Examples
#define uchar unsigned char
#define uint  unsigned int
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
#define CS_0           md_gpio_set_pin_low(CS_GPIO_PORT,CS_GPIO_PIN)
#define CS_1           md_gpio_set_pin_high(CS_GPIO_PORT,CS_GPIO_PIN)
#define WR_0           md_gpio_set_pin_low(WR_GPIO_PORT,WR_GPIO_PIN)
#define WR_1           md_gpio_set_pin_high(WR_GPIO_PORT,WR_GPIO_PIN)
#define DA_0           md_gpio_set_pin_low(DA_GPIO_PORT,DA_GPIO_PIN)
#define DA_1           md_gpio_set_pin_high(DA_GPIO_PORT,DA_GPIO_PIN)
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //?????
unsigned int i;
void delay(uchar x)
        for(i=0;i<x;i++);
void COMMAND_HT1621(unsigned char comm)
        unsigned char i;
        CS_0;
        delay(5);
        WR_0;
        delay(5);
        for(i=0;i<3;i++)        //???
                if((0x04<<i)&0x04)  DA_1;    //100
                else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        for(i=0;i<9;i++)        //?????
                if((comm<<i)&0x80)  DA_1;    //100
                else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        CS_1;
        delay(5);
void HT1621_Display(void)
        unsigned char i;
        CS_0;                        //??CS
        delay(5);
        WR_0;
        delay(5);
                if((0x05<<i)&0x04)  DA_1;
                else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        for(i=0;i<6;i++)                   //???
                if((20<<i)&0x20)    DA_1;  //20?? SEG??
                  else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        for(i=0;i<8;i++)                   //???
                if((DpyNum[5]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[4]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[3]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[2]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[1]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[0]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        CS_1;                          //??CS
        delay(5);
void LCD_Init(void)
        COMMAND_HT1621(0x01);         //SYS EN
        COMMAND_HT1621(0x03);         //LCD ON
        COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
        HT1621_Display();             //clear screen
  * @brief  This function configures GPIO
  * @param  None
  * @retval None
void config_gpio(void)
        md_gpio_set_pin_function(DA_GPIO_PORT, DA_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(DA_GPIO_PORT, DA_GPIO_PIN);
        md_gpio_set_pin_mode_output(DA_GPIO_PORT, DA_GPIO_PIN);
        md_gpio_set_pin_function(WR_GPIO_PORT, WR_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(WR_GPIO_PORT, WR_GPIO_PIN);
        md_gpio_set_pin_mode_output(WR_GPIO_PORT, WR_GPIO_PIN);
        md_gpio_set_pin_function(CS_GPIO_PORT, CS_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(CS_GPIO_PORT, CS_GPIO_PIN);
        md_gpio_set_pin_mode_output(CS_GPIO_PORT, CS_GPIO_PIN);
        md_gpio_set_pin_function(LED2_GPIO_PORT, LED2_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(LED2_GPIO_PORT, LED2_GPIO_PIN);
        md_gpio_set_pin_mode_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
  * @brief  Test main function
  * @retval Status.
int main()
        md_init_1ms_tick();
        config_gpio();
        LCD_Init();
        DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"?"
        DpyNum[1] = SegCode[1];
        DpyNum[2] = SegCode[3];
        DpyNum[3] = SegCode[5];
        DpyNum[4] = SegCode[7];
        DpyNum[5] = SegCode[9];
        HT1621_Display();               //??LCD
        while (1)
                md_delay_1ms(1000);
                //md_gpio_set_pin_low(LOAD_GPIO_PORT,LOAD_GPIO_PIN);
                md_gpio_toggle_pin_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
//                WriteWord (DisplayTest,TextEnd);  // ????????
//                WriteWord (Digit0,0);
//                WriteWord (Digit1,1);
//                WriteWord (Digit2,2);
//                WriteWord (Digit3,3);
                //SendChar (0X55);
效果图:
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
