[国产单片机]
【东软载波ESF0654 PDS开发板活动】+另一种HT1621
904|0
Cjy_JDxy|  楼主 | 2019-12-16 20:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
今晚捣鼓了一下另一种HT1621。
代码:
#include "main.h"
/** @addtogroup Projects_Examples_MD
/** @addtogroup Examples
#define uchar unsigned char
#define uint  unsigned int
unsigned int tmp;
unsigned int n1, n2, n3, n4;
unsigned char Ht1621Tab[]={0x00,0x00,0x00,0x00};
unsigned char DispTab[]={0x7B,0x12,0x67,0x57,0x1E,0x5D,0x7D,0x13,0x7F,0x5F,0x69,0x45,0x3f, 0x7a, 0x3e};
              //          0    1    2    3    4    5    6    7    8    9    C    ?   A     V     H
#define  BIAS     0x52             //0b1000 0101 0010  1/3duty 4com
#define  SYSDIS   0X00             //0b1000 0000 0000  ???????LCD?????
#define  SYSEN    0X02             //0b1000 0000 0010 ???????
#define  LCDOFF   0X04             //0b1000 0000 0100  ?LCD??
#define  LCDON    0X06             //0b1000 0000 0110  ??LCD??
#define  XTAL     0x28             //0b1000 0010 1000 ?????
#define  RC256    0X30             //0b1000 0011 0000  ????
#define  WDTDIS1  0X0A            //0b1000 0000 1010  ?????
void Ht1621_CS_0() { md_gpio_set_pin_low(CS_GPIO_PORT,CS_GPIO_PIN);}  // define P2.2 ---> CS
void Ht1621_CS_1() { md_gpio_set_pin_high(CS_GPIO_PORT,CS_GPIO_PIN);}
void Ht1621_WR_0() { md_gpio_set_pin_low(WR_GPIO_PORT,WR_GPIO_PIN);}  // define P2.1 ---> WR
void Ht1621_WR_1() { md_gpio_set_pin_high(WR_GPIO_PORT,WR_GPIO_PIN);}
void Ht1621_DO_0() { md_gpio_set_pin_low(DA_GPIO_PORT,DA_GPIO_PIN);}  // define P2.0 ---> DAT
void Ht1621_DO_1() { md_gpio_set_pin_high(DA_GPIO_PORT,DA_GPIO_PIN);}
unsigned int counter;
//????:Delay()
void Delay(unsigned char us)  //5,7,9
  while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
//Ht1621Wr_Data()
void Ht1621Wr_Data(unsigned char Data,unsigned char cnt)
  unsigned char i;
  for (i=0;i<cnt;i++)
     Ht1621_WR_0();
     if((Data & 0x80)==0x80) {Ht1621_DO_1();}
     else {Ht1621_DO_0();}
     Ht1621_WR_1();
     Data<<=1;
//void Ht1621WrCmd(uchar Cmd)
void Ht1621WrCmd(unsigned char Cmd)
   Ht1621_CS_0();
   Ht1621Wr_Data(0x80,4);          //??????100
   Ht1621Wr_Data(Cmd,8);           //??????
   Ht1621_CS_1();
//void Ht1621WrOneData(uchar Addr,uchar Data)
void Ht1621WrOneData(unsigned char Addr,unsigned char Data)
  Ht1621_CS_0();
  Ht1621Wr_Data(0xa0,3);  //??????101
  Ht1621Wr_Data(Addr<<2,6); //??????
  Ht1621Wr_Data(Data,4); //???????? 7  6  5  4
  Ht1621_CS_1();
//void Ht1621WrAllData()
void Ht1621WrAllData(unsigned char Addr,unsigned char *p,unsigned char cnt)
  unsigned char i;
  Ht1621_CS_0();
  for (i=0;i<cnt;i++)
    Ht1621Wr_Data(*p,8); //????
    p++;
  Ht1621_CS_1();
//void Ht1621_Init(void)
   Ht1621WrCmd(BIAS);
   Ht1621WrCmd(RC256);             //???????
   //Ht1621WrCmd(XTAL);             //???????
   Ht1621WrCmd(SYSDIS);
   Ht1621WrCmd(WDTDIS1);
   Ht1621WrCmd(SYSEN);
   Ht1621WrCmd(LCDON);
//DISPLAY
void Display(void)
   unsigned char com;
   com = 0;
   if((DispTab[n1]&0x01) == 0x01){ com = com + 0x10;}
   if((DispTab[n2]&0x01) == 0x01){ com = com + 0x20;}
   if((DispTab[n3]&0x01) == 0x01){ com = com + 0x40;}
   if((DispTab[n4]&0x01) == 0x01){ com = com + 0x80;}
   Ht1621WrOneData(0 , com);
   com = 0;
   if((DispTab[n1]&0x02) == 0x02){ com = com + 0x10;}
   if((DispTab[n2]&0x02) == 0x02){ com = com + 0x20;}
   if((DispTab[n3]&0x02) == 0x02){ com = com + 0x40;}
   if((DispTab[n4]&0x02) == 0x02){ com = com + 0x80;}
   Ht1621WrOneData(1 , com);
   com = 0;
   if((DispTab[n1]&0x10) == 0x10){ com = com + 0x10;}
   if((DispTab[n2]&0x10) == 0x10){ com = com + 0x20;}
   if((DispTab[n3]&0x10) == 0x10){ com = com + 0x40;}
   if((DispTab[n4]&0x10) == 0x10){ com = com + 0x80;}
   Ht1621WrOneData(2 , com);
   com = 0;
   if((DispTab[n1]&0x40) == 0x40){ com = com + 0x10;}
   if((DispTab[n2]&0x40) == 0x40){ com = com + 0x20;}
   if((DispTab[n3]&0x40) == 0x40){ com = com + 0x40;}
   if((DispTab[n4]&0x40) == 0x40){ com = com + 0x80;}
   Ht1621WrOneData(3 , com);
   com = 0;
   if((DispTab[n1]&0x20) == 0x20){ com = com + 0x10;}
   if((DispTab[n2]&0x20) == 0x20){ com = com + 0x20;}
   if((DispTab[n3]&0x20) == 0x20){ com = com + 0x40;}
   if((DispTab[n4]&0x20) == 0x20){ com = com + 0x80;}
   Ht1621WrOneData(4 , com);
   com = 0;
   if((DispTab[n1]&0x08) == 0x08){ com = com + 0x10;}
   if((DispTab[n2]&0x08) == 0x08){ com = com + 0x20;}
   if((DispTab[n3]&0x08) == 0x08){ com = com + 0x40;}
   if((DispTab[n4]&0x08) == 0x08){ com = com + 0x80;}
   Ht1621WrOneData(5 , com);
   com = 0;
   if((DispTab[n1]&0x04) == 0x04){ com = com + 0x10;}
   if((DispTab[n2]&0x04) == 0x04){ com = com + 0x20;}
   if((DispTab[n3]&0x04) == 0x04){ com = com + 0x40;}
   if((DispTab[n4]&0x04) == 0x04){ com = com + 0x80;}
   Ht1621WrOneData(6 , com);
//Display_lcd_dot
void Display_lcd_dot(void)
   Ht1621WrOneData(7 , 0x50);
//convertor()
void data_convertor(unsigned long adc_value)
    tmp=adc_value;         //adc
    n4=tmp/100;
    tmp=tmp%100;
    n3=tmp/10;
    tmp=tmp%10;
    n2=tmp;
                 // 4
    n1=10;       //display "C"
  * @brief  This function configures GPIO
  * @param  None
  * @retval None
void config_gpio(void)
        md_gpio_set_pin_function(DA_GPIO_PORT, DA_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(DA_GPIO_PORT, DA_GPIO_PIN);
        md_gpio_set_pin_mode_output(DA_GPIO_PORT, DA_GPIO_PIN);
        md_gpio_set_pin_function(WR_GPIO_PORT, WR_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(WR_GPIO_PORT, WR_GPIO_PIN);
        md_gpio_set_pin_mode_output(WR_GPIO_PORT, WR_GPIO_PIN);
        md_gpio_set_pin_function(CS_GPIO_PORT, CS_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(CS_GPIO_PORT, CS_GPIO_PIN);
        md_gpio_set_pin_mode_output(CS_GPIO_PORT, CS_GPIO_PIN);
        md_gpio_set_pin_function(LED2_GPIO_PORT, LED2_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(LED2_GPIO_PORT, LED2_GPIO_PIN);
        md_gpio_set_pin_mode_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
  * @brief  Test main function
  * @retval Status.
int main()
        md_init_1ms_tick();
        config_gpio();
        counter = 235;
        Ht1621_Init();        //?????LCD
        Delay(100);           //??????
        Ht1621WrAllData(0,Ht1621Tab,16);// Clear LCD display
        Ht1621_Init();
        while (1)
                md_delay_1ms(1000);
                md_gpio_toggle_pin_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
                data_convertor(counter);
                Display();
                Display_lcd_dot();
                counter++;
效果图:
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
