Qt安装问题
2689|2
taozhaogy|  楼主 | 2011-11-27 11:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI, ST, IO, TE, WATCH
我有个问题问问大侠们,我安装qt-embedded-linux-opensource-src-4.4.3.tar.bz2时,在make后提示错误如下,不知如何解决,还望高手能给帮助一下。
io/qfilesystemwatcher_dnotify.cpp:258: `F_SETSIG' undeclared (first use this function)
io/qfilesystemwatcher_dnotify.cpp:258: (Each undeclared identifier is reported only once
io/qfilesystemwatcher_dnotify.cpp:258: for each function it appears in.)
io/qfilesystemwatcher_dnotify.cpp:259: `F_NOTIFY' undeclared (first use this function)
io/qfilesystemwatcher_dnotify.cpp:259: `DN_MODIFY' undeclared (first use this function)
io/qfilesystemwatcher_dnotify.cpp:259: `DN_CREATE' undeclared (first use this function)
io/qfilesystemwatcher_dnotify.cpp:259: `DN_DELETE' undeclared (first use this function)
io/qfilesystemwatcher_dnotify.cpp:260: `DN_RENAME' undeclared (first use this function)
io/qfilesystemwatcher_dnotify.cpp:260: `DN_ATTRIB' undeclared (first use this function)
io/qfilesystemwatcher_dnotify.cpp:260: `DN_MULTISHOT' undeclared (first use this function)
gmake[1]: *** [.obj/release-shared-emb-arm/qfilesystemwatcher_dnotify.o] Error 1
gmake[1]: Leaving directory `/usr/local/qt-embedded-linux-opensource-src-4.4.3/src/corelib'gmake: *** [sub-corelib-make_default-ordered] Error 2
ycz9999| | 2011-11-27 13:43 | 只看该作者
不玩QT的帮顶
tcc8073| | 2011-12-9 16:12 | 只看该作者
ubuntu10.10里带有软件包,可以自动下载安装
