请教下各位大哥为什么这个电路用pspice模拟不了,问题在...
1308|1
 楼主| dgw 发表于 2019-12-19 20:55 | 显示全部楼层 |阅读模式
电路图
仿真结果
**** 12/19/19 20:46:49 ********* PSpice 9.2 (Mar 2000) ******** ID# 1 ********
** Profile: "SCHEMATIC1-ads"  [ D:\sp\TEST\ab-schematic1-ads.sim ]
****     CIRCUIT DESCRIPTION
** Creating circuit file "ab-schematic1-ads.sim.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Local Libraries :
* From [PSPICE NETLIST] section of d:\sp\PSpice\PSpice.ini file:
.lib "nom.lib"
*Analysis directives:
.DC LIN I_I1 0 0.15m 0.01m
.OPTIONS ITL4= 500
.PROBE V(*) I(*) W(*) D(*) NOISE(*)
.INC ".\ab-SCHEMATIC1.net"
**** INCLUDING ab-SCHEMATIC1.net ****
* source AB
G_G1         V 0 POLY(1) N15440 0 0.0 1
E_SIN2         N16790 0 VALUE {SIN(V(N16788))}
E_E1         N138052 0 POLY(1) V 0 0.0 1
E_GAIN1         N15440 0 VALUE {0.1m * V(N16790)}
I_I1         0 V DC 0.1m
X_INTEG1    N138052 N16788 SCHEMATIC1_INTEG1
C_C3         0 V  5p
R_R1         0 V  3.1438
I_I3         V 0 DC 0Adc AC 0Aac
+SIN 0 0.4m 100G 0 0 0
.subckt SCHEMATIC1_INTEG1 in out
G_INTEG1         0 $$U_INTEG1 VALUE {V(in)}
C_INTEG1         $$U_INTEG1 0 {1/3000000G}
R_INTEG1         $$U_INTEG1 0 1G
E_INTEG1         out 0 VALUE {V($$U_INTEG1)}
.IC         V($$U_INTEG1) = 0v
.ends SCHEMATIC1_INTEG1
**** RESUMING ab-schematic1-ads.sim.cir ****
.END
ERROR -- Convergence problem in DC sweep
  Last node voltages tried were:
NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE
(    V) 85.91E-06  (N15440) 2.155E-06 (N16788) 1376.4000 (N16790)     .0851
(N138052) 21.77E-06                   (X_INTEG1.$$U_INTEG1) 5431.7000
  These devices failed to converge:
    E_SIN2
ERROR -- Discontinuing simulation due to convergence problem
设置
是DC sweep 扫描I1,从0到0.3mA
I1貌似接反了  发表于 2019-12-20 08:31
dgw
