[运放] 聚洵低功耗运放GS358详细特性/规格书
1025|0
 楼主| Jence 发表于 2020-1-7 16:35 | 显示全部楼层 |阅读模式
Features
• Single-Supply Operation from +2.1V ~ +5.5V
• Rail-to-Rail Input / Output
• Gain-Bandwidth Product: 1MHz (Typ.)
• Low Input Bias Current: 1pA (Typ.)
• Low Offset Voltage: 3.5mV (Max.)
• Quiescent Current: 40µA per Amplifier (Typ.)
• Operating Temperature: -40°C ~ +125°C
• Embedded RF Anti-EMI Filter
• Small Package:
GS321 Available in SOT23-5 and SC70-5 Packages
GS358 Available in SOP-8, MSOP-8, DIP-8 and DFN-8
Packages
GS324 Available in SOP-14 and TSSOP-14 Packages
General Description
The GS321 family have a high gain-bandwidth product of 1MHz, a slew rate of 0.6V/ μ s, and a quiescent current of 40 μ
A/amplifier at 5V. The GS321 family is designed to provide optimal performance in low voltage and low noise systems. They
provide rail-to-rail output swing into heavy loads. The input common mode voltage range includes ground, and the maximum
input offset voltage is 3.5mV for GS321 family. They are specified over the extended industrial temperature range (-40 ℃ to
+125 ℃ ). The operating range is from 2.1V to 5.5V. The GS321 single is available in Green SC70-5 and SOT-23-5 packages.
The GS358 Dual is available in Green SOP-8, MSOP-8, DIP-8 and DFN-8 packages. The GS324 Quad is available in Green
SOP-14 and TSSOP-14 packages.
Applications
• ASIC Input or Output Amplifier
• Sensor Interface
• Medical Communication
• Smoke Detectors
• Audio Output
• Piezoelectric Transducer Amplifier
• Medical Instrumentation
• Portable Systems
Pin Configuration
Datasheet :
个人签名:启烨科技有限公司15889543533潘先生
28
