[入门教程] 定时器之One Shot 模式
4981|0
 楼主| ltbytyn 发表于 2011-11-29 12:32 | 显示全部楼层 |阅读模式
定时器 One Shot 模式。
不喜欢芯唐的函数库,过于臃肿,且不利于初学者深刻掌握芯片内部构架。故除通信部分外未使用函数库,便于真正理解定时器。
/* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved.                                         */
#include <stdio.h>
/*  Include hear file        */
#include "NUC1xx.h"
#include "DrvTIMER.h"
#include "DrvUART.h"
#include "DrvSYS.h"
#include "DrvGPIO.h"
static uint32_t volatile uTimer0Tick = 0;
static uint32_t volatile uTimer0Time = 0;
static uint32_t volatile uTimer0Type = 0;
void DrvIO_Init(void);
void Time0_One_Shot_Open(void);
/*  Sample Code Menu        */
static void TestItem (void)
    printf("\n\n");
    printf("+-----------------------------------------------------------+\n");
    printf("|               Timer Sample Program(One Shot)              |\n");
    printf("| 按下KEY1(GPB15)启动定时器0进入One Shot 模式               |\n");
    printf("| 执行一次定时器中断后退出                                  |\n");
    printf("| 启动流水灯                                                |\n");
void InitUARTDebugPort(void)
    STR_UART_T param;
    /* Select UART Clock Source From 12MHz */
    DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC, 0);
    param.u32BaudRate        = 115200;
    param.u8cDataBits        = DRVUART_DATABITS_8;
    param.u8cStopBits        = DRVUART_STOPBITS_1;
    param.u8cParity          = DRVUART_PARITY_NONE;
    param.u8cRxTriggerLevel  = DRVUART_FIFO_1BYTES;
    param.u8TimeOut          = 0;
    if (DEBUG_PORT == 1)
        DrvGPIO_InitFunction(E_FUNC_UART1);     /* Set UART1 pins */
        DrvUART_Open(UART_PORT1, &param);     /* Set UART1 configuration */
else
        DrvGPIO_InitFunction(E_FUNC_UART0);     /* Set UART0 pins */
        DrvUART_Open(UART_PORT0, &param);          /* Set UART0 configuration */
//    volatile uint32_t u32Reg;
GPIO_T * tGPIO;
tGPIO = (GPIO_T *)((uint32_t)GPIOA);
  tGPIO->u32PMD &= 0x0FFFFF00F;
  tGPIO->u32PMD |= 0x00000550;   //GPA_2、GPA_3、GPA_4、GPA_5为输出模式
GPIOA->u32PMD &= 0x0FFFFF00F;
GPIOA->u32PMD |= 0x00000550;   //GPA_2、GPA_3、GPA_4、GPA_5为输出模式
    DrvGPIO_Open(E_GPA, 2, E_IO_OUTPUT);   //GPA_2为输出模式
    DrvGPIO_Open(E_GPA, 3, E_IO_OUTPUT);   //GPA_3为输出模式
    DrvGPIO_Open(E_GPA, 4, E_IO_OUTPUT);   //GPA_4为输出模式
    DrvGPIO_Open(E_GPA, 5, E_IO_OUTPUT);   //GPA_5为输出模式
GPIOA->DOUT &= 0x0FFC3;       //GPA_2、GPA_3、GPA_4、GPA_5为输出0
    DrvGPIO_ClrBit(E_GPA, 2);
    DrvGPIO_ClrBit(E_GPA, 3);
    DrvGPIO_ClrBit(E_GPA, 4);
    DrvGPIO_ClrBit(E_GPA, 5);
GPIOB->u32PMD &= 0x0FFFFFFF;   //GPB_14、GPB_15为输出模式
GPIOB->PMD.PMD14 = 0x00;               //GPB_14为输出模式  0x00输入、0x01输出、0x10开漏、0x11准双向
GPIOB->PMD.PMD15 = 0x00;                  //GPB_15为输出模式
    DrvGPIO_Open(E_GPB, 14, E_IO_INPUT);   //GPB_14为输出模式
    DrvGPIO_Open(E_GPB, 15, E_IO_INPUT);   //GPB_14为输出模式
    SYSCLK->APBCLK.TMR0_EN = 1;
    TIMER0->TISR.TIF = 1;                //定时器比较中断标志,写1清0
TIMER0->u32TCSR = 0;      //关闭定时器
TIMER0->TCSR.MODE = 0;               //定时器单触发模式
TIMER0->TCSR.IE = 1;                 //定时器中断使能
TIMER0->TCMPR = 6000000;
    //NVIC_SetPriority((IRQn_Type)((uint32_t)TMR0_IRQn + (uint32_t)ch), (1<<__NVIC_PRIO_BITS) - 2);
    NVIC_EnableIRQ(TMR0_IRQn);
    printf(" 按KEY2(GPB_14退出流水灯) ...\n");
    TIMER0->TCSR.CEN = 1;
void DrvTIMER_Init(void)
    SYSCLK->CLKSEL1.TMR0_S = 0;     /* Set all the default TIMER clock sources are from 12MHz */
void TMR0_IRQHandler(void)
    if ((TIMER0->TCSR.IE == 1) && (TIMER0->TISR.TIF == 1))
    if ((TIMER0->TEXCON.TEXEN == 1) && (TIMER0->TEXCON.TEXIEN == 1) && (TIMER0->TEXISR.TEXIF == 1))
        TIMER0->TEXISR.TEXIF = 1;
    uTimer0Tick++;
uTimer0Time = 500000;
uTimer0Type = 0;
    printf("\n\nTIMER (One Shot Mode)Sample Code \n");
/*  MAIN function        */
int main (void)
    UNLOCKREG();
    SYSCLK->PWRCON.XTL12M_EN = 1;       /* Enable External 12M Xtal */
    DrvSYS_Delay(5000);          /* Waiting for 12M Xtal stable */
LOCKREG();
    SYSCLK->CLKSEL1.UART_S = 0;           /* Select UART Clock Source From 12MHz */
    InitUARTDebugPort();                  /* Initial UART debug message function */
    DrvSYS_Open(50000000);
    DrvTIMER_Init();
    TestItem ();
    DrvIO_Init();
while(1)
     if(uTimer0Tick)
         if(uTimer0Time >  200000)
    uTimer0Time =0;
    switch(uTimer0Type)
     case  0x00:
     GPIOA->DOUT |= 0x00038;      //GPA_2为输出0
     uTimer0Type = 1;
     break;
              //DrvSYS_Delay(500000);          /* Waiting for 12M Xtal stable */
     case  0x01:
     GPIOA->DOUT |= 0x00034;        //GPA_3为输出0
     uTimer0Type = 2;
     break;
     case  0x02:
     GPIOA->DOUT |= 0x0002C;      //GPA_4为输出0
     uTimer0Type = 3;
     break;
     case  0x03:
     GPIOA->DOUT |= 0x0001C;      //GPA_5为输出0
     uTimer0Type = 0;
     break;
     default :
     uTimer0Type = 0;
     break;
   else
       uTimer0Time++;
  if(GPIOB->PIN & 0x08000);      //GPB_15无按键
  else
            DrvSYS_Delay(500);          /* Waiting for 12M Xtal stable */
   else
    while((GPIOB->PIN & 0x08000) !=0x08000);
    while(GPIOB->PIN & 0x08000)
        Time0_One_Shot_Open();
     break;
  if(GPIOB->PIN & 0x04000);      //GPB_14无按键
  else
   else
    while((GPIOB->PIN & 0x04000) !=0x04000);
    while(GPIOB->PIN & 0x04000)
        uTimer0Tick = 0;
     uTimer0Time = 0;
     uTimer0Type = 0;
     GPIOA->DOUT |= 0x0FFFF;     //GPA_2、GPA_3、GPA_4、GPA_5为输出1
     break;
