[STM32H7]
串口DMA接收,哪里是接收数据存放处?
828|8
zhang..yb|  楼主 | 2020-2-14 10:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Configure the DMA handler for reception process */
  hdma_rx.Instance                 = USARTx_RX_DMA_STREAM;
  hdma_rx.Init.Request             = USARTx_RX_DMA_CHANNEL;
  hdma_rx.Init.Direction           = DMA_PERIPH_TO_MEMORY;
  hdma_rx.Init.PeriphInc           = DMA_PINC_DISABLE;
  hdma_rx.Init.MemInc              = DMA_MINC_ENABLE;
  hdma_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
  hdma_rx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
  hdma_rx.Init.Mode                = DMA_NORMAL;
  hdma_rx.Init.Priority            = DMA_PRIORITY_HIGH;
  hdma_rx.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;
  hdma_rx.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
  hdma_rx.Init.MemBurst            = DMA_MBURST_INC4;
  hdma_rx.Init.PeriphBurst         = DMA_PBURST_INC4;
  HAL_DMA_Init(&hdma_rx);
jackghl| | 2020-2-17 14:30 | 只看该作者
这只是初始化,还没调用 HAL_UART_Receive_DMA 函数。[em:3:
zhang..yb|  楼主 | 2020-2-18 15:24 | 只看该作者
/* Clean D-cache */
/* Make sure the address is 32-byte aligned and add 32-bytes to length, in case it overlaps cacheline */
SCB_CleanDCache_by_Addr((uint32_t*)(((uint32_t)tx_buffer) & ~(uint32_t)0x1F), TX_LENGTH+32);
/* Start DMA transfer */
HAL_UART_Transmit_DMA(&huart1, tx_buffer, TX_LENGTH);
请问 SCB_Clean... 这语句什么意思? 没这条就发不出
carefull3357dc| | 2020-2-18 15:32 | 只看该作者
DMA cpu不经过外设的内存直接访问单元吧?
zhang..yb|  楼主 | 2020-2-18 16:00 | 只看该作者
Transmitting data:
#define TX_LENGTH  (16)
uint8_t tx_buffer[TX_LENGTH];
/* Write data */
tx_buffer[0] = 0x0;
tx_buffer[1] = 0x1;
/* Clean D-cache */
Receiving data:
#define RX_LENGTH  (16)
uint8_t rx_buffer[RX_LENGTH];
/* Invalidate D-cache before reception */
SCB_InvalidateDCache_by_Addr((uint32_t*)(((uint32_t)rx_buffer) & ~(uint32_t)0x1F), RX_LENGTH+32);
HAL_UART_Receive_DMA(&huart1, rx_buffer, RX_LENGTH);
/* No access to rx_buffer should be made before DMA transfer is completed */
单收单发可以,同时收发数据出错
晓伍| | 2020-3-4 10:36 | 只看该作者
这部分代码里没有啊
八层楼| | 2020-3-4 11:10 | 只看该作者
接收数据代码没有啊
观海| | 2020-3-4 11:22 | 只看该作者
没用过dma  dma需要接收中断吗
guanjiaer| | 2020-3-4 11:57 | 只看该作者
没有用过dma啊
