[STM32L1] ADC模拟看门狗只在初始化时正常检测
722|15
 楼主| huangchui 发表于 2020-2-16 15:45 | 显示全部楼层 |阅读模式
STM32L151C8的ADC模拟看门狗只在初始化时正常检测
dengdc 发表于 2020-2-16 15:48 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
houcs 发表于 2020-2-16 15:51 | 显示全部楼层
先贴下代码:
/* GPIO 初始化部分 */
        GPIO_InitTypeDef GPIO_InitStructure;        /* MAC Pin */
        GPIO_InitStructure.GPIO_Pin =  MAC_GPIO_PIN;             /* PA0 */
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AN;
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
        GPIO_Init(MAC_GPIO_PORT, &GPIO_InitStructure);
/* ADC 模拟看门狗初始化部分 */
       ADC_InitTypeDef ADC_InitStructure;
        /* Enable the HSI */
        RCC_HSICmd(ENABLE);
        /* Wait until HSI oscillator is ready */
        while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
        /* Enable ADC1 clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
        /* ADC1 Configuration -----------------------------------------------------*/
        ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
        ADC_InitStructure.ADC_ScanConvMode = DISABLE;
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
        ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
        ADC_InitStructure.ADC_NbrOfConversion = 1;
        ADC_Init(ADC1, &ADC_InitStructure);
        ADC_ClearITPendingBit(ADC1, ADC_IT_AWD);
        /* ADC1 regular channel0 configuration */
        ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_4Cycles);
    /* Configure channel0 as the single analog watchdog guarded channel */
        ADC_AnalogWatchdogSingleChannelConfig(ADC1, ADC_Channel_0);
        /* Configure high and low analog watchdog thresholds */
        ADC_AnalogWatchdogThresholdsConfig(ADC1, MAC_HIGHER_THRESHOLD, MAC_LOWER_THRESHOLD);//0x16E
        /* Enable analog watchdog on one regular channel: channel0 */
        ADC_AnalogWatchdogCmd(ADC1, ADC_AnalogWatchdog_SingleRegEnable);
        /* Enable AWD interrupt */
        ADC_ITConfig(ADC1, ADC_IT_AWD, ENABLE);
        /* Enable ADC1 */
        ADC_Cmd(ADC1, ENABLE);
        /* Wait until the ADC1 is ready */
        while(ADC_GetFlagStatus(ADC1, ADC_FLAG_ADONS) == RESET)
        /* Start ADC1 Software Conversion */
        ADC_SoftwareStartConv(ADC1);
heweibig 发表于 2020-2-16 15:59 | 显示全部楼层
还没看到你得问题呢
 楼主| huangchui 发表于 2020-2-16 16:02 | 显示全部楼层
ADC模拟看门狗只能在调用初始化时,能够正常的转换电压(接的是3.3V,DR值为0xFFF),也能够正常的产生看门狗中断;但是初始化完成后当我将对应的管腿接到GND上后,发现DR的值还是0xFFF。再重新将对应的管腿接到3.3V上,DR当然还是0xFFF,但是却再也不会产生看门狗中断。
 楼主| huangchui 发表于 2020-2-16 16:06 | 显示全部楼层
若我在初始化时将管腿直接接到GND上,也能够正常的转换当然也不会产生中断;但是当我把对应的管腿接到3.3V时,DR值依旧是0,也不会产生中断?
jiahy 发表于 2020-2-16 16:10 | 显示全部楼层
楼主试一下换个中断标志看看
 楼主| huangchui 发表于 2020-2-16 16:12 | 显示全部楼层
shimx 发表于 2020-2-16 16:16 | 显示全部楼层
ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
void ADC1_IRQHandler(void)
  if(ADC_GetITStatus(ADC1, ADC_IT_EOC) != RESET)
    ADC_ClearITPendingBit(ADC1, ADC_IT_EOC);
lizye 发表于 2020-2-16 16:19 | 显示全部楼层
我之前也试过初始化的时候读到一次,中断没反映的,后来调试发现跟我配置的采样时间,检测的adc中断标志都有关系的。
jiaxw 发表于 2020-2-16 16:22 | 显示全部楼层
用的时钟源就是内部的RC吧
jiaxw 发表于 2020-2-16 16:26 | 显示全部楼层
嗯,最快速度只有16M
liliang9554 发表于 2020-2-16 16:29 | 显示全部楼层
把分频系数改大
 楼主| huangchui 发表于 2020-2-16 16:41 | 显示全部楼层
果然,我用的ADC的分频系数是1,也是16M。后来把分频系数改大就好用了!
wenfen 发表于 2020-2-16 16:45 | 显示全部楼层
模拟看门狗和普通的看门狗有设么不同吗
 楼主| huangchui 发表于 2020-2-16 16:49 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家
