[ZLG-MCU] LPC1756的CAN总线问题
3053|0
 楼主| wksljx 发表于 2011-11-30 20:09 | 显示全部楼层 |阅读模式
  旁路模式可以收到,ACCF_ON模式下不可以收到,请问是什么原因,要怎么设置,设置的程序 下:
/* Acceptance filter mode in AFMR register */
#define ACCF_OFF    0x01
#define ACCF_BYPASS    0x02
#define ACCF_ON     0x00
#define ACCF_FULLCAN   0x04
void CAN_SetACCF( uint32_t ACCFMode )
  switch ( ACCFMode )
case ACCF_OFF:
   LPC_CANAF->AFMR = ACCFMode;
   LPC_CAN1->MOD = LPC_CAN2->MOD = 1; // Reset CAN
   LPC_CAN1->IER = LPC_CAN2->IER = 0; // Disable Receive Interrupt
   LPC_CAN1->GSR = LPC_CAN2->GSR = 0; // Reset error counter when CANxMOD is in reset
break;
case ACCF_BYPASS:
break;
case ACCF_ON:
case ACCF_FULLCAN:
   LPC_CANAF->AFMR = ACCF_OFF;
   CAN_SetACCF_Lookup();
break;
default:
break;
  return;
