[ZLG-MCU] 关于CGU_InitClks
2364|0
 楼主| shuaibaobao 发表于 2011-11-30 20:56 | 显示全部楼层 |阅读模式
{CGU_SB->BCR[SYS_BASE_ID] = 0;                                       /*  禁能 BCR                    */
    CGU_FdivConfig(0, 1, 1, 2);                                         /*  FDC0 1/2分频                */
    CGU_SB->ESR[APB0_CLK_ID] = SELECT_FDC0 | ESR_EN;                    /*  选择FDC0                    */
    CGU_SB->ESR[APB1_CLK_ID] = SELECT_FDC0 | ESR_EN;
    CGU_SB->ESR[APB2_CLK_ID] = SELECT_FDC0 | ESR_EN;
    CGU_SB->ESR[APB3_CLK_ID] = SELECT_FDC0 | ESR_EN;
    CGU_SB->ESR[APB4_CLK_ID] = SELECT_FDC0 | ESR_EN;
    CGU_SB->ESR[AHB_TO_INTC_CLK_ID]  = SELECT_FDC0 | ESR_EN;
    CGU_SB->ESR[ARM926_BUSIF_CLK_ID] = SELECT_FDC0 | ESR_EN;
    CGU_SB->ESR[ISRAM0_CLK_ID] = SELECT_FDC0 | ESR_EN;
    CGU_SB->ESR[ISRAM1_CLK_ID] = SELECT_FDC0| ESR_EN;
    CGU_SB->ESR[ISROM_CLK_ID]  = SELECT_FDC0 | ESR_EN;
    CGU_SB->ESR[INTC_CLK_ID]   = SELECT_FDC0 | ESR_EN;
    CGU_FdivConfig(1, 0, 0, 0);                                         /*  FDC1 1分频                   */
    CGU_SB->ESR[ARM926_CORE_CLK_ID] = SELECT_FDC1 | ESR_EN;             /*  选择FDC1                     */
    CGU_FdivConfig(5, 1, 1, 2);                                         /*  FDC5 2分频                   */
    CGU_SB->ESR[CLOCK_OUT_ID] = SELECT_FDC5 | ESR_EN;                   /*  选择FDC5                     */
    CGU_FdivConfig(6, 1, 1, 2);                                         /*  FDC6 2分频                   */
    CGU_SB->ESR[EBI_CLK_ID]   = SELECT_FDC6 | ESR_EN;                   /*  选择FDC6                     */
    CGU_SB->BCR[SYS_BASE_ID]  = BCR_FD_RUN;                             /*  使能 BCR                     */
    CGU_SetBaseFreq(SYS_BASE_ID, CGU_FIN_SELECT_HPPLL1);                /*  设置SCR[0],选择系统PLL       */
    CGU_SB->BCR[AHB0_APB0_BASE_ID]  = 0;                                /*  禁能BCR                      */
    CGU_FdivConfig(8, 1, 1, 2);                                         /*  FDC8 2分频                   */
    CGU_SB->ESR[AHB_TO_APB0_PCLK_ID] = SELECT_FDC8 | ESR_EN;            /*  选择FDC8                     */
    CGU_SB->ESR[IOCONF_PCLK_ID]      = SELECT_FDC8 | ESR_EN;
    CGU_SB->ESR[CGU_PCLK_ID]         = SELECT_FDC8 | ESR_EN;
    CGU_SB->ESR[SYSCREG_PCLK_ID]     = SELECT_FDC8 | ESR_EN;
    CGU_SB->BCR[AHB0_APB0_BASE_ID]   = BCR_FD_RUN;                      /*  使能 BCR                     */
    CGU_SetBaseFreq(AHB0_APB0_BASE_ID,CGU_FIN_SELECT_FFAST);            /*  设置SCR[1],选择FFAST         */
初学ARM,目前在用SMARTARM3130,上面是时钟设置,但搞不懂程序中分频是分的那个时钟?是输入的晶振时钟吗?
